Craftex Mill/drill, Orangeville, ON $500
trlvn
Looks like a smoking good deal at $500:
https://www.kijiji.ca/v-power-tool/oakville-halton-region/crafted-knee-mill-vertical/1491838400
I'm surprised it is still listed after two days on Kijiji. I thought about buying it and flipping it for double the money. For me, however, it is just not worth it since I'd have to rent a vehicle and probably a 2 tonne shop crane.
DavidR8
Scrap maker
Heck I'd buy it from a distance!
Looks like it sold. Anyone here?
Tom Kitta
Yeah that is a smoking good deal - but not the only one in ON - I saw multiple Bridgeport clones for just ... $2000 (!!!) or even less (!!!)
BTW that mill is not that heavy - you could have rented a pickup from HD and shop crane is like $20 if you need one - you could just man handle this mill with some wood planks - it is no more then around 500 lbs.
DavidR8
Scrap maker
If that was an RF 30 clone they run close to 700 lbs. Heavier than they look.
Tom Kitta
http://www.micro-machine-shop.com/rong_fu_rf_25_mill.htm
RF-25 weight 440 boxed 374 net.
https://www.rongfu.com/en/Milling-Drilling-Machine/RF-31.html
RF-31 manufacturer spec 505
Google says RF-30 is 400 lbs.
RF-40 could be more like 700 lbs especially if you add stand and vice.
When a mill in AB came at ultra low price I immediately called and had my dad drive there within like 30min - you got to be fast.... but I have not seen any good deals in years now - even don't look too hard anymore. ON has plenty.
DavidR8
Scrap maker
My apologies, I had 700# in my head for some reason.
trlvn
I have a very similar model. The manual for my Craftex B1977 says the net weight is 270 kg without the stand which is 600 pounds.
They are pretty top heavy so there is a non-trivial risk of the machine falling over. There is a way to feed a strap down through the headstock, behind the quill, to help with lifting. (I think it was David's thread on Hobby Machinist where I learned that.) At least on mine, however, the sheet metal belt guards have to come off first. And the spindle pulley and idler pulley both have to be removed to get the guards off. I think that should be fairly simple to do but it does take time. When I eventually move mine to the basement, I'll do that.
BTW, the ad was gone just after lunch today. It would be funny if the buyer turned up as a new user on the site in the next little while!
Tom Kitta
RF-40 is... 270 kg - they have bigger table and more travel then RF-30.
Yes they are top heavy - some pp even remove the top and move them in pieces - I assume to the basement.
At that price range I would hope it would be gone or else some pp may want to drive from AB to ON just for it ;)
DavidR8
Scrap maker
I now think I should have cut a hole in the sheet metal so I could drop a chain through the head without having to remove the pulley etc to lift it up again.
Mind you I can always use a strap.
How many pieces can you break those things down to and what do the pieces weight? Approx.
DavidR8
Scrap maker
https://rick.sparber.org/Articles/MoveMill/MoveMill.htm
This was this inspiration for how I moved mine.
Removed the motor. Solid 40lbs
Unbolted the column.
Walked it down a ramp. Pretty sketchy to be honest. Almost lost it at one point because I didn’t lower the head. Wasn’t thinking clearly.
Slid the base down the ramp.
I had it out of the back of my truck in 45 minutes.
kevin.decelles
Yyc - think of all future tool moves in terms of dishwasher size chunks. Going down, weight isn’t that relevant
Let’s get you a bigger mill!
