Coal forge build
I thought I had read somewhere that the coal out of the upper Hat cr. was supposed to be good? .... But then, some miss guided soul thought it to be a good idea giving me false hope in some stupid rabbit that comes along each spring too.......😳
So, Jr and I lit the forge for the 2nd time today and had some fun for a bit.
L-R are the only things I have forged in chronological order so far.
#1 A coal rake. 1st thing I forged with my propane forge, Daughter did the loop on the handle. Made a few months back.
#2 A fire poker 1st thing I forged with my coal/coke forge, Son did the loop on the handle
#3 A small "damascus" billet of a portaband blade, and steel strapping. This was my first forge weld and it went well. I still need to cut and stack it again. Probably only going to do that once more before turning it into something yet to be determined. Probably a better version of the next item.
#4 A divot tool for my FIL for fathers day.
That was a challenging one. I took way too many heats on this, and I burnt up some steel in the process (when I was in the garage trying to find punches.....), but it was pretty fun to get an idea I had earlier in the week out of my head and into steel. I REALLY need to make some tooling to help make future projects like this easier. I need some hardy tools to start with, A hot cut, a bending jig, A variety of proper punches.....Then I need to make some tongs.....vise grips are a PITA......
New hobby should keep me busy for a while. 😀
I also want to make a new, smaller propane forge too.....I have a forge building problem....
Wierd???? I can't see the images in your post but I can see them when I quote it????? And then they disappear again when I post the quote????
Ya, it's something to do with Imgur links. They used to work just fine. They show up when I write the post, then disappear when I post it. For the way I post it's a PITA to upload pictures to the forum. I usually post the same build thread on other forums, and use their editing features, then copy and paste it here. Having to connect my phone to my computer and download the images to my laptop, then upload them to the forum, is another layer I frankly just don't want to deal with. I gave it a shot for the start of this thread, but tried to get the old way working for this update with no success. 🙁.
Just upload them directly to the forum from your phone. Skip the laptop and imgur. That takes a layer away instead of adding one. It's easy. That's how I ALWAYS do it!
Then I have to type on a touch screen, hard no. What was working before was a great system. I'm hoping it's just a glitch in the matrix that can be fixed.
I think you could do all your typing on a computer. Then don't press submit. Just logon with your phone, refresh to get your draft, add the photos from your phone, and submit.
But honestly, I don't find typing on a phone all that difficult. And I'm an old man with shaky hands.
I only had about 45 minutes today between some other commitments, but I snuck out the shop and jammed this out quick from some offcuts that were lying around. I tigged it all because it was already out, and I need the practice.
I even painted it too. I'm going to weld a 2" receiver to the forge to mount this. And a couple more on the ends for a vise or other accessories. This should be a lot more sturdy than the tri legged stool that came with the blower. I've already knocked it over twice, and I can see now why this housing has been welded at some point in it's history......
Shop time has been hard to come by the past couple weeks, busy summer, but earlier today I snagged a few hours before my baseball game tonight to chip away at my forge hood. I'm home now, with some recurring flared up sciatica I get to post about it from the couch instead of finishing it....
This is all scrap pile driven so I drew a quick wireframe based on the sheet metal I had laying around, and I liked the look of this radius cornered bed frame I had in the barn when I went digging so it got the nod.
I like curves, and incorporating them into as much as I can, so I wanted to do a kerf bend in this to form the side curves, while keeping the edge radius. I printed out some paper templates with critical dims scribbled on it and got to work. Marked the bends from each end, and layed out the kerf spacing the old fashioned way by walking some dividers.
I needed at least an 0.08" kerf and decided to try doubling up some 0.045" cut of discs instead of using a 1/8" one, vs 2 cuts with the porta band. Face shield AND safety glass for this one.....My apprehension was unfounded as it was pretty uneventful and turned out great.
Some of the cross braces had some holes and slots I had to work around. I pre filled this one in before cutting it free just to keep the pieces in place. It'll all get welded up solid later.
With all the kerfs cut and parts pre bent I did some brainstorming for a quick welding jig to tack them all together.
With them all tacked together, I grabbed the stool, sat down and welded them up solid with a series of alternating tacks.
Backside showing some nice penetration. Should cleanup nice.
Remember this guy...
Undecided about filling all the other holes and slots. Those ones are on the backside and hidden, purely cosmetic, but it'll bug me.... We'll see how much time I have when I get back to them....You'll also notice 2 are different sizes. I only had one side of this rounded bedframe, so the smaller ones (with the holes and slots) were the cross members, and the bigger ones will go on the front. Trust me, it'll be fine 😉 lol
I did clean up one of them to see how it looked before having to get to ball.
A few pinholes left unfilled, but not too bad. Good enough for what it is....Still a bit more work on the forge itself too before I can call it done and get it setup permanently. I can't wait to finish it, and a few other tools before I can really get into some blacksmithing projects.
That's all for now. Not sure when I'll get back to it, but now that the Kids baseball is all done now, that's a few nights a week I'll get back from running around and coaching. Always a bittersweet time. I miss it, but I'm glad it's over...I'll be glad when mine is done too.
Nice. Please keep posting photos. I've been wanting to build a fume hood for over my foundry furnace and welding table for years and just never had the courage to attempt it.
The hood will be a necessity for where I want to stick the forge. I have an old shed in the backyard that up until now has mainly been untouched since we bought the place and filled with a lot of old farm/animal stuff from the previous owner. I've finally (only took 13 years....) been chipping away at cleaning it out and finding new homes for stuff, and hopefully by the fall will have my forges and anvil all setup and vented under the roof, so I can continue without relying on the weather. I eventually want to build a new lean to off the back of the barn for my smithy, but for now this shed is the path of least resistance. This setup will be temporary......But nothing is more permanent than a temporary solution so......
Well.....I didn't think it would be this long until I got back to this, but life got in the way......
Spent this weekend getting a bit farther on this and a few other projects. I can't say "finished" yet, because it isn't, but I made some major headway.
We last left off with all the curved uprights done, so I setup some angle guides on the welding table at 12" apart so I could start building the frame.
Pretty nice having the new shop computer and tv out there with the MotoGP practice one in the background. I got it all tacked up, then welded every joint solid, and ground them all smooth
One of the reasons I hadn't got to finishing this, is because I needed some sheet metal. I didn't like my original plan of using the scraps of this galvanized I had laying around, so I kept checking marketplace and kijiji for some used stuff. I lucked out earlier this week by snagging two of these 24x71" sheets of 10ga for $20. Enough to finish this, and another unfinished project that's also been hanging around too long (hard to believe eh?)
I traced out all the sides, and cut them out with the plasma. Then cleaned them up with my new to me big boy grinder and wire wheel. What an awesome tool.
My original plans has some light duty sheet metal making this curve on the sides, but I was able to bump bend the 10ga every 1/2" or so with some molson muscle and over bent a bit so I could clamp it tight to weld. Worked better than I thought it would.
Satisfied with the look and fit, it was time to flip the hood down and weld it out.
I just happened to look out the back door at the right time and catch this Mom and her daughter walking across the back treeline behind the barn. Always nice to see.
And here it is all "done" for now.....
I still have to weld the top on, ring roll a flange for the exhaust pipe, and cut the opening, but that will have to wait for a while. I have a busy next couple of weeks.
Hopefully it won't be another 2 months before the next installment. I really want this installed and working by the first snowfall......
View attachment 38572View attachment 38571View attachment 38558
Very nice work indeed,
keep up the solid work!
