Product Chuck for rotary table
Product
Diverse1
Scored a really clean Meca 16” rotary table recently to add to the collection. Weighs about 200lbs but finally got around to getting it onto the table with the engine hoist. Looks like I might need a stand-off extension for the turret on my Wells Index 887…..not a lot of clearance otherwise….now need to source an appropriate chuck to mount on this too…suggestions/pictures anyone?
By the time you get a chuck on there, it going to be bit crowded. 8in. or bigger chuck? You have a collection of rotary tables? I have 2, a 3in. and a 6in, possibly all I may need, but hay, never know.
Nice looking mill!
Mounting a plain back chuck is relatively easy with an adapter plate. Even if you have D-pins for a lathe setup you can temporarily remove them. Some plate considerations:
- bolt pattern to match your RT slots obviously
- be aware of height stack-up by the time you mount the plate + chuck + work, then tooling coming down from the top.
- a through hole in plate to allow stock or fixture arbors to extend into, otherwise stock length will bottom out on the plate (limited by your chuck body through hole)
- if you have different chucks with different bolt patterns, try & incorporate them both into one universal plate while you are locating & making holes anyways
- an afterthought unrelated to RT (not shown) depending on the size of the plate, mill 2 flats superimposed on the OD & that will allow you to clamp the plate + chuck in the mill vise. Or if you want to mount it to your mill table, figure out those T-slot spacing dimensions beforehand
Nice looking mill!
Just the one rotary table…by “collection” I meant tools/equipment in general…
In all the years I've used a rotary table, I've never once used a chuck on it. Its not that I couldn't, I just haven't. I usually just indicate the work in or use an MT3 arbour in the table center and clamp the work down using the T-Slots.
I wonder if using a chuck on a rotary table is more down to doing multiples/short production.
If you only have to dial in one piece, mounting a chuck is a pain, in fairness.
But if you're doing a bunch of parts, or the same operation on a regular basis (mount this ring/cylinder, and knock X number of equidistant tapped holes in it, lets say), a chuck is a godsend.
The first shop I worked in made mostly traditional brass wall sconces and chandeliers. The chandeliers had a rolled brass ring, usually 1/4" thick, brazed, with a shoulder turned on both sides to match spinnings or stampings. The shop had a Burgmaster turret drill with a rotary table and a three jaw chuck permanently mounted. You tossed the rolled and brazed ring on there, tapped it pretty much true, and drilled and tapped between 3 and 12 holes in it to mount the arms of the chandelier (1/8 or 1/4 NPSM).
What? You've never used a RT vertically?
Sure I have. Same deal. A center or a dialed in part.
I also have a 5C spindexer and tailstock. I use the spindexer A LOT!
Kinda makes sense. The 5C collet chuck on the lathe also gets used more than all my other chucks combined.
I think you nailed it. I don't recall ever working on more than one copy of a part. Even if I had 2 copies I'd probably still do it the same way as I have. But a half dozen is a different kettle of fish.
Thanks for the pictures and insight! This is really helpful.
