Don't know if this belongs here.
I purchased 4 turntables for $30 about a month ago. They were all sitting outside on a concrete patio, covered in dust, kinda piled on top of each other.
This is the Pioneer before I started the servicing/cleaning.
Took it apart. Replaced all the electrolytic capacitors, replaced the neon bulb and series resistor for the strobe, and performed general cleaning, greasing, etc.
Finally, followed the user and service manuals to set it up. Seems like a decent turntable. It definitely plays a record and all the features work. Just missing one nut for the mounting cartridge hardware. On order.
Has an interesting strobe light feature (neon bulb) that is used to set the speed. When the platter is spinning if you see the dotted line through the viewing window moving left or right you can adjust the speed with a thumb wheel. Once the line is perfectly still the speed should be correct.
Now, just have to figure out how to mount it inside my truck...for when I am driving
Of the remaining turntables I have a Marantz and Nikko to look at. The 4th was garbage.
