Casting 1/8 scale steam locomotive parts
Tobho Mott
Last casting day we didn't do very well with the locomotive parts. Pictures can be found here.
I've been given a shot at molding the parts I now know to be called the Motion Support Frames.
Here are some pictures of the patterns for one of the frames (there is a left and a right one) with the core prints in red and the pattern itself in grey.
Now here are some.pictures of the patterns he dropped off yesterday. It took me a few confused minutes to realize the paint job isn't the same anymore, one half of the whole split pattern is now red and the other half is grey, rather than the cour being an indication what is pattern and what is core print.
The other split pattern and it's coreboxes are a mirror mirror mage of these. The 2 cores go together sitting one on top of the other in the mold.
Here are some linseed oil bonded cores, enough of them to try each casting twice if I need to.
Some of them are a little worse for wear after being driven a couple hours to get them here. I have the coreboxes if I end up needing to make any new ones.
I need to decide how I will do the gating. It's a tricky one with 2 long skinny sections one on top of the other with a core in between, and I am not at all sure what the approach should be. The tiny gate built into the pattern that he had sprued directly down onto didn't work out last time...
I spoke with Denis Foster (makes CI straight edges) and he suggested gating into the end sort of like as shown, but through a large riser that can keep supplying hot metal.
Another friend who's been pouring cast iron for a while suggested gating in from the end would never make it to the far end, and that a runner with gates that tunnel under the core to fill from the side is the best way to go .
I'm not sure. I have some time to think about it. I think I will pick the 2 most likely seeming suggestions approaches and try both, all at once. I might only get one more iron pour day in this year, otherwise I'd try whatever I decide seems like the way that seems best first, and only try plan B if that fails.
Denis' idea worked! Got one of the two mirror image cast iron Motion Support Frames done.
I will stay that it's not the prettiest casting ever. The 3D printed pattern has some small issues, and my sand needs some love. But the whole part is in there somewhere.
The fins deep in the drag were tricky to draw out of the sand cleanly. This was my 2nd try. With a wooden pattern, rapping on it up at the parting line also works to loosen the features deeper in the mold... With a mostly hollow thin walled plastic pattern, this seems less true.
I lose this edge in the cope from the boss all the way down the casting every time, that goes for both patterns. Sorry for poor lighting. Might be zero or slightly negative draft there. Could use a slight radius on that external corner as well.
Here's the best of the 2 sets of linseed oil bonded cores I was left with for this side. A little.ragged. I'd assumed they just didn't travel all that well from Sydenham to my place outside Ottawa, but I heard from Doug and he also blames his 3D printed coreboxes for being difficult to get a clean draw from.
A bit of shrink on this boss in the cope will be getting drilled out and hopefully not matter. Doug isn't worried about it so I'll do the second part the same way, but a riser on top of that boss would eliminate the defect.
I wasn't sure I got all the details at the far end. It looks a bit odd because the pattern's draft there was changed at some point but the corebox wasn't, which allows some metal to seep around the end of the core.
But on closer inspection, it's all there. There is supposed to be a gap in that end.
One down, one to go.
The mirror image pattern drag side gave me fits!
3 times I rammed it up and 3 times the middle fin of sand in that deep section broke off. The 3rd time I had even rammed up a screw in the mold to strengthen and support that bit of sand. I knew it had to be an issue with the pattern and for that 3rd attempt the screw did help keep most of that sand to stay put. I decided it was good enough to pour as the extra metal could probably be milled out.
Aside from that and the fact that it didn't quite fill, it actually came out looking a little nicer than the first casting in some ways. A pity. Another 50 degrees and I think I'd have had it!
In a way it's good it didn't fill. I would never have felt great about the breakout in the drag. While it was a waste of time and fuel and wear and tear on my sand and Doug's crucibles, it did give me another chance to mold the thing better.
I got Doug's permission to work on his pattern a little. It's amazing what 10 minutes with a file and a couple scraps of sandpaper can do! 🙂
I haven't poured it yet, but it:s ready to go when I find time for an iron casting session in the next few days sometime.
I am surprised how bright the iron looks straight out of the Petrobond sand. My greensand makes iron castings that have a much darker outer oxide skin. Something about the oil in the sand creating a reducing atmosphere inside the mold, or perhaps just making a layer of smoke between the iron and the sand. But I do lose the oil bonded sand that was in direct contact with the iron every time I use it this way.
Ideally I would use greensand for all iron casting and Petrobond for all nonferrous, but I wasn't about to haul a thousand pounds of sand in and out of my sheds and really deep-clean out the muller, twice, to switch over from Petro to green and back for just 2 small castings. I simply toss a scoop of new Petrobond into the muller with each load to make up for the burnt out sand I discard after an iron pour.
I do have a second muller, sort of based on the one I built, taking up most of the useful floor space in my pattern shop. Its builder attached the crossbar to the legs instead of the yoke, disabling what would be a handy built in dump-out mechanism. It's wheels and plows kinda suck too. I need to make time for it before it can be really useful to me. That and building a second molding bench would let me run both types of sand simultaneously. Not sure how to fit it all in my casting shed though...
Jeff
Thanks! He told me what train he's building but I forget. I'll try and remember to ask again. if it sheds any light, I know "G3J" comes into it somehow (his handle on another forum). I also know that the National Science and technology museum in Ottawa has lots of engineering drawings for it that he was able to access. But their collection is huge, so I'm not sure that narrows it down too much
I got some pics and footage some of his parts and patterns that might(?) help ID his loco, meanwhile. Skip to the 20 minute mark here to see:
If nothing else, his patterns are quite interesting.
Jeff
I’m guessing this (gorgeous) engine is what your friend is making. Chief of motive power in CPR at the time was H. Bowen who was famous for standardizing successful designs. The drivers and running gear of the CPR G3 class of Pacifics like your friend’s model were from the same patterns as were used to make the Royal Hudson 4-6-4’s. The Hudson’s just had a larger firebox for sustaining high speed passenger service.
Both had the reputation of being highly successful engines.
@Collector may want to comment?
Jeff
The answer is obvious. Build another shed. Everybody needs a petrobond shed and a greensand shed. 🙂 good read, thanks for sharing. I'm impressed with the quality of your castings.
I just picked up three 50lb bags of sodium bentonite for cheap so I can make another batch of green sand whenever I get some time to get back to casting. Most likely wont be until next year, but the local deal was too good to pass up.
Super cool! I think you're right that that's what he's building. Nice catch.
I do need a new, bigger shed! One that is less wooden. Especially if I'm ever going to get the A70 furnace running. Right now it's just a 1000# PPE shelf that takes up enough floor space for a second muller!
I'll be needing a gantry crane too, please.
I've been watching marketplace for cheap carport/garage in a box kits or the like.
Jeff
Here's another look at the same part on the Royal Hudson at the science museum here in Ottawa. Doug just sent it to me, and confirms he is building a G3 which has the same distinctive part. You can see the curved arms painted black in the background, which were a little harder to see in Lucky7's pic above.
Jeff
