Here’s a translation of the first page.
Good luck.LOL
FO.00 |Inverter power specification |Display current power
FO.01 |Main Controller Software Version|Display the current software version number
0: Panel run command channel
FO.02 |Run command channel selection|1: Terminal run command channel
2: Communication operation command channel
0: Panel potentiometer
|1: Number given 1, operation surface
Panel ▲, ▼ key adjustment
|2: All analog setting (0~10
10.10~99.99KW model setting
1.00~99.99
1.01
10~2
0
V/0~20mA
3: Digital setting 2, end terminal UP
IDO WN adjust frequency
4: Two-stage speed terminal access to the given
And run, terminal UP/DO
WN adjust frequency
5: Two-stage speed terminal trigger setting
And run
FO.03 | Frequency setting selection
0~6
0
6: Communication setting
FO.04 Running frequency digital setting|The setting value is frequency digital for 10.0~upper limit frequency| 50.0Hz| 0
