Can anyone on this forum translate a Chinese instruction manual for me?
Bought a VFD on Amazon and the programing manual is in Chinese. No English manual supplied.
Can anyone here help me?
Thanks,
gerritv
Gerrit
On the Amazon page it says to contact customer service for English manual (way down in the reviews/questions area.
@Johnwa what does your phone app think of these?
  • VFD1.pdf
  • VFD2.pdf
  • VFD3.pdf
  • VFD4.pdf
Tom Kitta
Maybe use instructions from some other unit? This should not be such a mystery, you connect 240V on one side 1ph and get 3ph on the other. The trick is mainly in... how do you change speeds, wire extra on off switch etc.
On the plus side it is only 68 CAD now.
I wired it up and it ran fine right out of the box. Max freq was 50HZ and I wanted to up that a bit. I figured out how to do that by looking at the defaults listed. It now cycles 0-80HZ and the setting is being saved when powered down. Now I want to figure out how to get it to run in reverse, and I'm only assuming it can be done. It has a DIR led?
What do you think the MF-K button means and is for? These instructions are really bad, I don't see any dissertation explaining the button functions.
Tom Kitta
I have used mine like 5 year ago. Got two of them, one died. "customer service" did reply and simply blamed me for broken unit.
Johnwa
Here’s a translation of the first page.
Good luck.LOL
FO.00 |Inverter power specification |Display current power
FO.01 |Main Controller Software Version|Display the current software version number
0: Panel run command channel
FO.02 |Run command channel selection|1: Terminal run command channel
2: Communication operation command channel
0: Panel potentiometer
|1: Number given 1, operation surface
Panel ▲, ▼ key adjustment
|2: All analog setting (0~10
10.10~99.99KW model setting
1.00~99.99
1.01
10~2
0
V/0~20mA
3: Digital setting 2, end terminal UP
IDO WN adjust frequency
4: Two-stage speed terminal access to the given
And run, terminal UP/DO
WN adjust frequency
5: Two-stage speed terminal trigger setting
And run
FO.03 | Frequency setting selection
0~6
0
6: Communication setting
FO.04 Running frequency digital setting|The setting value is frequency digital for 10.0~upper limit frequency| 50.0Hz| 0
Good luck.LOL
1.00~99.99
1.01
10~2
0
V/0~20mA
WN adjust frequency
And run
0~6
0
Thanks for trying !!!
Apparently MF-K stands for multi function key and according to some of the manuals I have been looking at I should be able to program it to behave as a reverse run key.
Johnwa
Here you go
HJH
|0: The console is idle
1: Wire control stop/run
FO.21 |input terminal X1 function|2: keyed stop/run
3: Key operation
|4: Keyed stop
5: Wire control forward running
6: Wire control reverse operation
0~26
X
7: reserved
Input terminal X2 function 18: error reset signal
9: Wire control forward and reverse switching
10: Keying forward and reverse switching
11: Keyed forward running
12: Keyed reverse operation
13: Multi-speed 1
14: Multi-speed 2
15: Multi-speed 3
16: External error signal
17: Jog forward
18: Jog reversal
FO.22 |
0~26
2
X
FO.23 | Input terminal X3 function
0~26
7
X
FO.24 | Input terminal X4 function | 19: Emergency stop
0~26
0
X
20: Relay control
21: Clear terminal frequency
22: Terminal frequency increases
23: Terminal frequency decreasing
24: Select stage speed 1 and run
25: Select stage speed 2 and run
26: Multi-speed shutdown (only for
24 and 25 functions are valid)
FO.25 | Input terminal X5 function
0~26
0
O
One
Johnwa
And this is from google translate
■LU.VU HJト4 U | 0: Control terminal idle 1: Wire control stop/run input terminal X1 function | 2: Key control stop/run 3: Key control operation 4: Key control stop 5: Wire control forward running 6: Wire control reverse operation 7: Reserve FO.21 0~26 1 X input terminal X2 function 18: Error reset signal FO.22 0~26 2 X 9: Wire control forward and reverse switch 10: Key control forward and reverse Switch 11: keyed forward running 12: keyed reverse running input terminal X3 function | 13: multi-speed 1 FO.23 0~26 X 14: multi-speed 2 15: multi-speed 3 16: external error signal 17: point Moving forward 18: Jogging reverse FO.24 | Input terminal X4 function | 19: Emergency stop 0~26 0 X | 20: Relay control 21: Terminal frequency clearing | 22: Terminal frequency increasing 23: Terminal frequency decreasing 24 : Select stage speed 1 and run | 25: Select stage speed 2 and run 26: Multi-stage speed stop (only valid for functions 24 and 25) FO.25 | Input terminal X5 function 0~26 0 7
Johnwa
With the google app you can pick out specific sections to translate. That might give better results.
