Calgary- Delrin bushings
N
Neil B
Guest
I'm looking to get some delrin bushings machined for 2 carburetor throttle spindles. I would need a total of 4 bushings.
Each bushing is:
  • made from 9/16" nominal diameter delrin rod
  • has a 9/32" center hole
  • approximately 0.835″ in length
  • has a 0.59" long section cut to an OD of of 0.380" - 0.0385"
Here is a quick CAD drawing I made:
If I am getting these made I might as well also have them pressed into the carb bodies and bored out/aligned.
I got the idea for this on a blog written by a gentleman from Maine. He outlines how he manufactures and installs the bushings in the link below.
It's quite a long post so I would suggest that once you are on his page, use ctrl + f to search for the following text "Delrin bushings that I use in Type HIF-6 carburetors". This will take you to the relevant section.
HIF-6 Rebuild
I have not taken this to a professional shop yet and I would ideally like it done this week or even this weekend. I can source the rod. I'm located in the SW but would be willing to travel to any part of the city.
Thank you in advance,
Neil
I decided to try printing said parts with my new 3D printer. Here in the photo you can see two with two more printing in the background. I think - think - they will be ok with gasoline due to the attached chart. The printing material is PETG. No guarantees though. I think they turned out as pretty good parts. I upped the density to 70% from the default 20%.
http://sevierlab.vet.cornell.edu/resources/Chemical-Resistance-Chart-Detail.pdf
@Neil B PM me and we can see if you want these parts.
Photos. So does the forum think this would be ok in an engine?
Alexander
Well abs is very unstable in fuel. PLA resists gasoline for a little bit.You would need to print it out of nylon if you have any hope of it standing up to the gasoline. Looks good John, I like that you are always trying stuff,
This is not pla or abs. Its PETG so that might be better. Needs more research.
kevin.decelles
John, looks like you got your printer printing diameters accurately. Did you end up changing anything ?
Odd - external diameters are fine - the internal ones are still out. I'm not sure why your clone is better. ???
