Bristol #0 with mods
Got the spindle done today! it's coming together.
Got the drive sorted today, Just waiting on belts. Wired in my mod for the speed adjustment and estop and got some paint on some of it today! Tomorrow photos of the 90% completed project : )
Hi Don! Yes lots of fabrication on this one. It's been fun. Still a few things I'd like to do, probably when I'm installing the scales for the DRO. I'm almost across the finish line, I still need a belt, scales that I'm picking up next week and I think I will add oilers and grooves to the y axis and flake it a bit, I did the X when I was modifying the table. So here's where I landed.
Z total travel is 15.5, X has 10 normally, in a pinch I can remove the end support and get another 4 so capable of 14 total. Y is 4.5 I will make a fixture plate for this table because of it's small size. the head assy has 5+" of travel which is the acme with the thrust bearing originally it was on a rack but the gear had beed damaged so I converted it. the location of the acme was originally a travel limit rod but the casting it fit through was missing so I made one from 4" square tube. The Quill has 4" of fine feed using a worm drive. The head rotates 180 degrees on the reducer. The servo motor is 1HP and driving 1 to 2, top motor speed is 5000 Rpm so a 2500 spindle speed is max. It is adjustable from 0 to 2500with the brass knob.The DRO is 3 axis I have power feed on X only The spindle has beed converted to R8 from B&S 7 should be much more useable. I'll make one more post on this thread once the scales are on and everything is working
