MrWhoopee
Sorry, I dropped the last "l"The second link doesn't take me to anything.
what is the difference between the H2 and M2 inserts?
A little searching reveals that the BAP300r uses the APKT/APMT1135 insert while the BAP400r uses the APKT/APMT1604 insert.I have both, but I find that the smaller inserts will do everything I need, which is .100 DOC in heat-treated 5140 (HRc 40-42)I am currently looking at this https://www.aliexpress.com/item/32975142215.html?spm=a2g0o.productlist.main.27.69a3txxMtxxMzK&algo_pvid=3cac1654-9b9e-45f5-8041-3c733cbc38f4&algo_exp_id=3cac165A4-9b9e-45f5-8041-3c733cbc38f4-13&pdp_npi=4@dis!CAD!47.41!45.99!!!242.76!235.49!@2101c5c317264394738601725e78b8!10000001876998093!sea!CA!6114728300!X&curPageLogUid=XzC5ryfF0Ka2&utparam-url=scene:search|query_from: I like the free shipping it feels like less of as gamble if it doesn't work out I"m not out the shipping. My only hang up is I don't know what BAP300R and BAP400R means so I don't know what to select. I have been googling like crazy and can't figure out what the difference is or even what it means.
I just Googled each one individually, then checked the insert size for the cutter.Thank you so much I have spent an embarrassing amount of time trying to google that and figure that out. Could you please post a link to that info I would love to read it and learn.
I'm not sure if it's because I have been searching face mills on aliexpress for the past few days but when I tried to google anything to do with BAP300R all that came up was places selling face mills probably 90% of the links were aliexpress. After going 3 pages deep on google I would try something a little different and get the same results.
I have fly cutters and have used them for the last 7ish years and they work good except I have found that the HSS dulls very fast when cutting through mill scale and rust. So I would like to finally get into some carbide insert tools.
Do they work well? I have the same 3 piece fly cutter set I would have to get some brazed carbide small enough to fit them or make a larger fly cutter. I have a few cheap brazed carbide kicking around I think they are 3/8" shank if I recall.I use brased carbide lathe tools on my fly cutters.
Buy Tool Bit Carbide Bl8-c5 3pcs at Busy Bee Tools
B3519 3pc Carbide Tipped Brazed Tool Bits For general machining operations Feature C6 carbide tip for cutting steel and steel alloys Type: BL8www.busybeetools.com
Buy Fly Cutter 1/2" 3pc Set at Busy Bee Tools
Fly Cutter SetTop QualityCounter balancedMade of hardened steelUses standard tool-bitsShank Dia.: 1/2"Includes Head Dia.: 3/4", 1 1/8", 1 1/2"Standard Tool Bit Size: 3/16", 1/4", 5/16"www.busybeetools.com
That's a good idea those are the same type of inserts I have for the lathe.I bought inserted left-hand turning tools for my flycutters. One of them uses the "free" corner of the CCMT inserts that I use on my lathe, so I have a continuous supply.
