Battery for digital ID micrometer
I decided to buy an electronic inside mic from Ali. From what I can tell, its a lower priced ringer for Shars. Delivery was fine & arrived without battery which they state in the description.
But they say battery is LR44 1.5v. I have some of those but they are much smaller diameter & thicker than the cavity The instructions are Chinese, zero English, so I cant corroborate. Strangely. Shars does not mention either. I don't want to put a larger diameter button cells in because they are generally 3v. Anybody here read Chinese if I post the instructions? I sent in a question but I think its their New Year break. Sheesh. Are there other dimensional formats of LR44?
Get the Google translate app on your phone and it will use the phone camera to read the text and translate.
Google says direct replacements for LR44 would be Duracell 76A, Energizer A76, and AG13 batteries. These batteries are exact equivalents for the LR44 battery, the only difference being the name. These batteries can all be interchanged.
Yes it says A76,V13GA on the card of my LR44 as an equivalent, but as you can see by pic, the battery is much smaller diameter than the cavity & I believe LR44 is thicker as well.
@David_R8 I'll try a translator
Downloaded Google translate. It said 3V CR2032 battery, when battery is lower than 2.8v replace it.
Stuck in a CR2032, the digits came on & no magic smoke.... so far
Surely I can't be the first guy to stumble on this?
If I get a response I'll post but I think I'm good to go. Thanks David!
Most tools like that use LR44s and LR44s are Alkaline. I prefer comparable (same voltage) lithium.
Glad you got the right size sorted out.
I admit that I don't know as much as I might like about battery chemistry, but is there a reason to avoid Alkaline?
I didn't think there were many lithium equivalents to SR 44 but maybe @Susquatch has investigated further. Lithium is typically nominal 3v basis not 1.25-1.5 but maybe these button cells are a different exception. I don't like old school alkaline because they have a tendency to puke their innards over time. Some lower quality electronics <cough> like Chinese measurement devices, have a tendency of current draw even when 'off'' & deplete the cell into these conditions. Lithium generally has better capacity & discharge metrics over other chemistry, but that may not be a factor on low demand devices. I'm talking non-recharchable cells here. Chargeable cells is a different game again.
The biggest single reason is what I call battery rot. When a cell goes dead undetected they can leak and ruin the equipment they are in. There are so called leak proof alkalines (the eveready ones with the nike swoosh), but I've had a few of those go too. So I prefer to avoid alkaline totally except for cheap equipment. I buy the Eveready by the carton for that. My good stuff all get lithium or long life batteries. If I do put alkalines in something like Flashlights, I remove the batteries and set them down beside the equipment, and only install them when in use.
I don't think there is lithium replacement for the lr44 either. I thought I had said lithium or long life but apparently I only mentioned lithium - my bad. For the lr44 family, I use a 357 which I believe is silver oxide. Costs more but doesn't leak.
There are lots of lithium replacements for AA, AAA, and even AAAA which are all 1.5V so it isn't a chemistry limitation. It's just that there aren't any LR44 lithiums that I know of. If there were I would use them over silver oxide for the extra life.
