This is one I was looking at:I'll let you know if I find some.
I bought one of the bearing nuts - "just to see if I could tell the difference". I couldn't, really. That said, most of my ER32 stuff in question came straight from AliExpress. One R8 ER32 "CanCNC"came from BB, and was likely from China or India with a bit better finish. It all works well enough for me, but perhaps paying a few hundred per holder, from a 'western' manufacturer would make a difference. I'll never know.![]()
ER 32 Ball Bearing Collet Nut
www.shars.com
So do i need one of these for my ER32s or is it something that would be nice to have?
When do you find this starts to happen? High chip load, RPM, interrupted cutting...? The bearing style doesn't seem expensive & its not like they require dedicated holders so seems like good insurance.Using them on my CNC I can tell you that unless you're a gorillia regular nuts do not tighten enough when you do something stupid and your endmill will slip. The Ball nuts well easy to tighten and loosen, no slip.
Don't your ER collet holders have flats so you can put a wrench/spanner on the holder while you tighten the collet nut? Is your mill spindle R8 or Morse taper?ER collet are not keyed , like 5C, R8......
Yes my holder has flat.Don't your ER collet holders have flats so you can put a wrench/spanner on the holder while you tighten the collet nut? Is your mill spindle R8 or Morse taper?
Ah, I understand now. I never paid any attention to whether the collet was rotating, Other 'one piece' collet types (like R8) that just 'pull straight in' wouldn't produce the same problem. And if you are trying to hold the end mill for sharpening, rotation matters.Yes my holder has flat.
Its the collet itself rotating in the holder which also rotated the endmill I am trying to sharpen, Not by much but enough to shift the cutting edge that I am trying to sharpen with the grinder. If the ER collet was keyed it would not rotate in the holder.
Its the collet itself rotating in the holder which also rotated the endmill I am trying to sharpen, Not by much but enough to shift the cutting edge that I am trying to sharpen with the grinder. If the ER collet was keyed it would not rotate in the holder. Hopefully the ball bearing nut will reduce the friction between the collet and the nut to prevent it from rotating in the holder
I think what @fixerup means is that the endmill flute has to sit on the tooth rest of the grinder so that the grinding wheel is properly positioned, but when you go to tighten the collet nut, it squirms slightly out of position.I confess that this is sooooo hard for me to accept. The ratio between tightening the nut and gripping friction of both surfaces of the collet is enormous. The force exerted on the endmill flutes when you sharpen them cannot be very much at all.
Have you cleaned all the oil out? Everything should be dry.
Are the tapers all clean or is there some dirt in there?
Is something else moving?
Am I missing something?
Regofix (the inventor of ER collets) has a chart of recommended torque and holding force here:
Thanks for that link. Interesting, their torque spec for ER40 is 128 NM which is 94 LB FT. Lots of other sources specify 130-140 LB FT for ER40. I guess I've been over tightening!I confess that this is sooooo hard for me to accept. The ratio between tightening the nut and gripping friction of both surfaces of the collet is enormous. The force exerted on the endmill flutes when you sharpen them cannot be very much at all.
I found this one on Amazon.I think just nice to have. But I want one anyway. Even if just to try. Not ordering from Shars or China though. But didn't see any on Amazon. I'll let you know if I find some.
