AXA Tool Holder(s)
I was looking at my AXA tool holders and got to thinking.... With a mill and a shaper I should be able to make these things.
As a first go I thought I'd use some of this funky 1" thick aluminum stock I got from @kevin.decelles and @RobinHood (@Janger originator) Thanks guys.
The trick now was how to liberate that 3" X 1.5" piece on the bandsaw......
Took some fooling around but I eventually got her LOL....
Next up was throw it on the mill, square it up and mill out the majority of the dove tail
Finally on the shaper. That setup was a bit of a head scratcher.....
One side of the dove tail done.....
And the second side......
Bummer:mad: She's too wide by at least 0.069" Don't know how that happened..... I checked my tool holders against the Shar's website and came up with the same numbers?
Oh well. Try again I guess......
Tom Kitta
Don't worry I screwed up my first set in CX as well - metal was hard and had other issues.
But my 2nd set in AXA came out perfect, way better then Chinese stuff, top quality, like US made stuff. Very snug.
I may do some more, just boring bar holders in oversize variety, like 1", 1.25" or maybe even huge like 1.5" I probably just make two and add adapters.
deleted_user
I was looking at my AXS tool holders and got to thinking.... With a mill and a shaper I should be able to make these things.
As a first go I thought I'd use some of this funky 1" thick aluminum stock I got from @kevin.decelles @RobinHood (@Janger originator)Thanks guys.
Bummer:mad: She's too wide by at least 0.069" Don't know how that happened..... I check my tool holders against the Shar's website and came up with the same numbers?
did you see that video of the guy using hand powered shaper to make tool holders? You got it easy compared to that guy ;)
Everett
Hey, process still looks good for a first attempt, even if it is a bit big! I've made a few pieces to fit my BXA post. I cheated by taking readings between pins on my best-fitting import holder to get my dimensions, even for when I made drawings before starting a project.
Ian Moss
I have two AXA 250-001 tool holders I ordered in ignorance. The Ali website pic showed the toolpost, but the number indicated the holder. These look well made and even have an inspection sticker ;-). I would part with the two for $20 and $5 shipping if you can't pick them up in Sherwood Park Alberta. Also open to an interesting trade.
deleted_user
You know that line from The Hunt for Red October... "The average ruskie son, dont take a dump without a plan". I modified it for my motto,... I need a full set of construction drawings before I even get out of bed.
not being a machinist it helps me work out the order of operations
Hmmmm.... isn't 250-001 actually a 0XA tool holder?
Ian Moss
Hold the presses. Craig pointed out to me that what I have is OXA not AXA. They are available if anyone wants them.
Darren
Craig, i did one on my shaper that i spent a lot of time on before cutting the dovetails...i should have cut the dovetail first...but i ended up welding it up and recutting it, and it worked out great.
Craig, i did one on my shaper that i spent a lot of time on before cutting the dovetails...i should have cut the dovetail first...but I ended up welding it up and re-cutting it, and it worked out great.
Ya, I hear you on that. Not going to finish to dimension again until the dovetail proves out. The other thing that has occurred to me is that the dovetail could probably be cut with a fly cutter on the mill....maybe?
Darren
Maybe. I bought a few dovetail cutters on Ebay for the mill, so i've been using those now.
whydontu
I Tried, It Broke
now I see the appeal of a shaper. looks like fun.
Dan Dubeau
Bummer about the fitment, but the old saying goes, those who've never make mistakes, never make anything.
If you shim it permanently, make sure to do it on the back side. It's the front side (closest to spindle) of the dovetail that is the most critical register surface for repeatable tool changes (part diameter), and the back is basically for tightening. Not sure what kind of toolpost you have or whether it registers on the face of the block, the tails themselves, or the bottom of the dovetail slot, but you might be able to get away with cutting that off, cleaning it up and remounting it with SHCS in a tighter position. Or even making a new block that screws on. There are lots of ways to fix it, but the answer depends on some variables. I think an epoxied shim would be more than servicable for an aluminum toolholder. If it falls off after x number of uses, just re glue it. You could also bend it over the edges and screw it that way too. The clamping force of the toolpost will hold it where it needs to be in use.
I made my OXA holders out of a big long rusty and bent piece of steel I bought at a farm auction many years ago (apart of a bigger lot of a bunch of steel bought for less than scrap). You never know what can be hiding inside a piece of material until you start cutting.
Hacker
Ya, it is....and rather relaxing.... swish, swish, swish, swish as you stand there down feeding the tool. Figuring out tool geometry can be frustrating though, lots of chatter if it's not right.
Sort of like watching a power hacksaw. I drag mine out every now and then just to watch it work. LOL
RobinHood
@YYCHM , as has been stated, your process is right on the money. The fit is a bit off, but you can fix that.
For your second attempt I suggest you make a vise stop for the shaper. It will allow you to take the part out of the vise to try and fit it onto the tool post. This allows you to sneak up on dimensions.
Remember with dovetails, both the depth and and width need to be correct for proper fitment. Measuring across pins is a combination of both depth and width. So it may be perfect, but still won’t fit.
