As mentioned in @Canadium ’s thread I also purchased some items from the same auction.
The highlights include:
Several comparator type indicator stands, two mitutoyo and one granite one that’s unbranded.
A dividing head with chuck
A sine plate
Two cylinder squares*
A nice tapping head (or tap collet holder?) which was a real steal at $15 complete with a full set of collets. It’s clutched but non-reversing. MT3 shank and collets with a MT2 bore in addition to the tap collets for drilling without changing the tool holder.
*It turns out that one of the cylinder squares is not really a cylinder square. Though it can be used as one and is very accurate for that purpose.
I was curious about these holes in the side so I looked up the patent number on the bottom. After some head scratching I figured out that it is a pneumatic plug gauge. It’s about .001” smaller than the nominal gage size stamped on the bottom. It’s inserted into the bore to be gauged and air is passed through the gage to the holes in the side. The change in pressure caused by air escaping through the bore provides a measurement.
A sine plate
