Should still support the other end of the pinion shaft. Don't use the pot bushing to handle any load."sliding (vertical) rack in a channel and pinion on the pot shaft"
My plan B, above.
My plan B, above.
Yes that was one of my fatal mistakesShould still support the other end of the pinion shaft. Don't use the pot bushing to handle any load.
Thank goodness I will never have to worry about having that scenario also.It's like software. Sometime you have crumple up the page and toss it in the trash and start fresh.
The word "software" should be replaced with "Microsoft Windows"
There's nothing wrong with your solution and the mechanical characteristics of the 1/4" shaft pot are what make it work so well! Change that to an 1/8" shaft and it's not really meant for that sort of load. But again, all it takes is a bearing support on the other end.I am almost embarrassed to show you this, but it has worked so well for many hours over many years that I guess it is worth having a look at. The cord from the spring, around the pot knob to the foot pedal is a very fine nylon covered? multi-strand cable, but lots of other things should work. I cobbled it together for a job winding magnetic coils with the intention of improving it if the whole winder worked, but it worked so well I never had a reason to change it. Occasionally the cable may slip a bit and off is not off, but you just draw the spring down to take the tension off, reset the pot and good to go.
Ha ha I love it!I am almost embarrassed to show you this, but it has worked so well for many hours over many years that I guess it is worth having a look at. The cord from the spring, around the pot knob to the foot pedal is a very fine nylon covered? multi-strand cable, but lots of other things should work. I cobbled it together for a job winding magnetic coils with the intention of improving it if the whole winder worked, but it worked so well I never had a reason to change it. Occasionally the cable may slip a bit and off is not off, but you just draw the spring down to take the tension off, reset the pot and good to go.
The 1/4 shaft is better, no doubt, but notice that the cable is in a straight line, and the tension above and below is balanced when not in motion, adding no bending moment to the shaft. When travelling, the difference between the top and bottom segments of the cable are only the small torque of the pot. Pots are cheap, can you substitute a more robust pot if you are worried?There's nothing wrong with your solution and the mechanical characteristics of the 1/4" shaft pot are what make it work so well! Change that to an 1/8" shaft and it's not really meant for that sort of load. But again, all it takes is a bearing support on the other end.
occasionally the cable may slip a bit and off is not off,
