Any solutions to my problem?
I am almost embarrassed to show you this, but it has worked so well for many hours over many years that I guess it is worth having a look at. The cord from the spring, around the pot knob to the foot pedal is a very fine nylon covered? multi-strand cable, but lots of other things should work. I cobbled it together for a job winding magnetic coils with the intention of improving it if the whole winder worked, but it worked so well I never had a reason to change it. Occasionally the cable may slip a bit and off is not off, but you just draw the spring down to take the tension off, reset the pot and good to go.
There's nothing wrong with your solution and the mechanical characteristics of the 1/4" shaft pot are what make it work so well! Change that to an 1/8" shaft and it's not really meant for that sort of load. But again, all it takes is a bearing support on the other end.
Ha ha I love it! :) Often simple is best. I seem to start with a simple idea and it grows unnecessarily complex often times.
I'm giving my #3 version attempt at this thing mostly because I'm learning alot and need practice at some things. I'm going to attempt to cut my own nylon gears using a new dividing head and I'll likely screw up using that once or twice also. Despite my frustrations, I am kind of enjoying myself o_O.
The 1/4 shaft is better, no doubt, but notice that the cable is in a straight line, and the tension above and below is balanced when not in motion, adding no bending moment to the shaft. When travelling, the difference between the top and bottom segments of the cable are only the small torque of the pot. Pots are cheap, can you substitute a more robust pot if you are worried?
occasionally the cable may slip a bit and off is not off,
That could probably be dealt with by anchoring the cable to the knob at one point. I like this. Yes, "Often simple is best".
