Anodizing for Dummies?
someidiot
Well-Known Dismemberer
A quick search reveals that there are those among us who do aluminum anodizing.
Can anyone offer a reasonable beginner's guide to it? Not looking to do anything fancy, just basic black for a start for boat parts.
Thanks - found it. But really - how much can I trust a bloke who says "aluminium"?
My Mother (Laboratory Chemist back in the 30's & 40's) would frequently say "Aluminium," but she was somewhat of an Anglophile. One of her wedding presents (1939) was a small Aluminium tray & coaster set, probably more expensive than the Seth Thomas Mantle Clock she received ($25: I only know this as she got $25 from an Aunt her directed that it be spent on the clock).
My shop anodizing system is basic but does a nice job.
A bucket of 35% H2SO4;
A bucket of sodium bicarbonate;
A bucket of tapwater;
A bucket of NaOH;
An adjustable power supply - 12-24v and 1 to 10 amps.
Titanium wire;
Lead strips for the cathode;
The trick is in the cleaning of the aluminum part.
Clean the part in the NaOH first - that removes any surface crap. Then rinse thoroughly in fresh water.
IMHO only an etching cleaner will do this properly on a hobby budget. By far the best aluminum prep is Dynaflux 781 or UltraBrite. which include phosphoric acid. Both available from AirLiquide etc. Gloves required. After dunking the part in this and rinsing under the tap several times - any surface oils will be removed and the surface has a micro-etch that seems to accept the anodizing well.
The part is wired (use gloves to keep the surface oil free) and connected to +ve with the lead strips wired to -ve and laid out in the acid bucket.
I use a fairly high current (theres a calculator for current/voltage/surface area) but in reality all you need to do is watch the bubbles when adjusting the current.
About 10 minutes is enough for a shallow decorative surface. If a deeper coating is needed, crank up the amps and leave it longer.
The anodizing dyes used are quite expensive. Don't be tempted to try fabric dyes, they do not work.
To colour the part, prepare the dye concentrate and heat it to 60C. Submerge the part and keep the fluid agitated. It takes between 2 and 10 minutes to dye the part, and you can use masks and multiple layers if you want to get fancy. When the colouring cycle is complete, rinse the part in fresh water and you're done.
Anodizing
Some finished parts
Hot dye
Angle base for a rotary table, hard anodized.
Umm... "cool", I guess. But note the subject line, so it's probably not reasonable to expect me to know WTF "Type II" means.
Well, ok, I guess I shouldn't have assumed that you've done zero homework 😛
Type II (Room temperature or "decorative anodizing") can be done using a variety of electrolytes but the most common is Sulphuric acid, which can be hard to acquire for the hobbyist so many other baths can be made if necessary. Industry stand is 180g/L but some hobbyists use a lower bath density known at LCD (low current density) which works but takes twice a long in general.
Water make up should consist of Deionized or at least distilled water.
Degreasing your parts is a must with a good surfactant (soap for those that don't want to google 😛)
It's imperative that the parts be de-smutted prior to anodizing to remove any "noble" metals from the surface (copper, zinc.....) to achieve a "pure" or as pure as possible aluminum surface for even crystal growth. You can buy proprietary bath chems or the hobbyist use a mild sulphuric bath (10 - 20% by weight).
In simple terms anodizing it's done using 12 ASF for 45 minutes to an hour (depending on dye colour used) or the 720 rule (google it) and almost all "job shops" run 12ASF (unless milspec) because there's no math required for surface area.
Once a sufficient coating has developed (10 - 25 microns) you pull the part, rinse it well in Di water then dye it in a chemical based dye stuff! Hobbyists will use organic based dyes like Rit but it's not colour safe so UV exposure can fade it quick. Temp should be 140 deg.
After that the parts are rinsed again then it's sealed (Preferably in a nickel based mid temp sealant for best results), but again a hobbyist can us plain boiling Di water and submerge the part in it for 25 minutes.
That's a very dumbed down process explanation, any questions I can help you with that narrow down things to provide a successful outcome, let me know.
SOP for me to ask very preliminary questions before doing any homework at all, esp. when still in "idle curiosity" phase.
Yes, thanks very much. It allows me to build a rough picture in my head so I can think about sourcing supplies, etc.
Available Stable Funding?
African Swine Fever?
Alien Sex Fiend (I actually saw that band once - very nice people)?
Avocados Sans Frontieres?
LOL you have an over active mind, it refers to "Amps per square foot" and as a fun note, I didn't know what SOP meant.....so I googled it 😉
Like I said the topic can be very broad, so once you have a better idea of what direction you want to go you will likely have more specific questions....if not then no biggie!
