Aluminum rods
RobinHood
There was a video of a fellow using them... wish I could think of his name
maybe it was this one?
Johnwa
@RobinHood
The ones kms has are low temperature. They claim you can use a propane torch. I think the ones @Tom O linked to are similar.
i have an aluminum repair I need to get after and may just give them a try.
Tom O
Here is one of the 3 in one soldering / brazing vid's He gives a good testing to the process. Once he hangs up his dam coat! :rolleyes:
Tom O
Another one here on thread repair stripping a aluminium thread with a torque wrench fixing it with rod then stripping again with the torque wrench comparison.
Johnwa
I broke the handle on a big drill and want to repair it. Its likely older than I am and is too well made throw out,
DavidR8
Scrap maker
You might have to get that TIG’ed if it has to bear much load.
I wondered if those low temp aluminium brazing rods were highly skill dependent. ie. way better than me.
@Johnwa if you want to come over and try TIG on that please just ask. I've welded a motorcycle clutch handle back together with it so I think your drill handle sounds similar.
KMS doesn’t have any rods in Calgary anyway.
Why am I not surprised. They haven't been able to fulfill any of the orders for stuff I have attempted to placed over the last two years. All refunded. I've pretty much given up on them.
Tom O
A scrap of copper behind the weld and you should be fine.
And if you want to try those 3 in 1 rods that could happen also.
Tom Kitta
If this is the stuff to "stick weld" aluminium give it a pass. It "works" sort of but not really. I guess if you are on a desert island and have nothing else to weld aluminium with its better then nothing. But out of 10 I would give it a 1. 0 wold be if it does not work.
I have aluminium TIG rod and lifetime supply of steel TIG rod. I think I also have lots of stainless TIG rod (another lifetime) as well as some silicon bronze.
You could also MIG aluminium if you had a push-pull gun and AC supporting welder.
BTW, stick welding aluminium electrodes are super expensive - about 100x more then they are actually worth (which is slightly more then AL scrap).
Welding with a torch could be an option - certainly it cannot be worse then stick & probably much better.
ersatz engineer
BTW I MIG aluminum all the time without a spool gun. I use an old 'Clarke Weld' 80 amp, and run it through normally. never get a cobble using .035 wire.
With Dabbler's encouragement I've had a go at MIG aluminium without a spool gun - it generally works for me. When it does not I get a burn back into the tip which plugs it. If I don't notice then I get bird nest too!
Tom O
I have a older Millermatic 135 it comes with stitch, spot and pulse with another dial for burn back .023 though. But I’ve never considered using aluminum in it!
ersatz engineer
The secret of the Clarke is that the torch length is very short - about 4 feet. That helps a lot. I keep it around to do aluminum only.
