Maybe it can be a forum bonding event and we can do it on the Saturday meet-up
But in all seriousness, hopefully Friday.
You could always bring to the meet-up as a show and tell
Yes, the fellow showing me the machine fortunately had it all hooked up. It looks like he fully lubricated since posting the advertisement. It looked pretty dry in the photos he uploaded. We ran it in each speed of the gear box. This model comes with a clutch, but one of the push rods looked a bit bent so the clutch couldn't fully decouple. That should be an easy fix. The only thing we did not check was the total stroke adjustment.Did you witness it running?
I did joke in the meetup thread that everyone should bring their favourite machineYou could always bring to the meet-up as a show and tell![]()
Yesss! Now that makes me feel good.So she is going to come home with me!
Have done well with a Tow truck, as far as loading and unloading heavy iron goes. By the time I tipped the guy enough to buy him a box of beers, it still cost me less than two boxes of beers!Trailer and a gantry crane, or trailer and hire a picker truck for an hour
Or trailer and a ramp/pipes/come along or winch
Edit;
Worst case....driver direct
Maybe more risk than using a Rigger outfit, but we are usually not dealing with $100K+ machinery either.
My latest move was a 3000# surface grinder. I used a tilt deck trailer from United Rentals. The seller had some 4” wide strips of hard plastic (~1/2” thick) - walked it along with a crow bar, then pulled with a comalong. For the drive I put the machine down on the wooden trailer deck (3000# is easy enough to lift with a bar and only had a 1/2” to go). Other methods would be fine too, just sharing what worked well for me on this move.I was expecting to be able to rent a drop deck trailer from sun-belt rentals but they no longer have it listed on their website. Does anybody have any suggestions for how to move this home? The seller did say they are happy to help move it via fork lift onto a trailer if needed.
I'm trying to find a spec on the weight of the shaper, but I have reason to believe it is over 1500 lbs and my Dad's truck bed is only rated to 1300 lbs.
That's a very generous offer of you! I believe I have a plan that will work but I'll keep you posted haha! Thanks!There are a couple of drop decks at Sunbelt in Okotoks, I have used one a couple of times now. I am fairly sure will be at the Calgary meet on Sat., so worst comes to worst, load it in my truck with fork lift. Unload at my shop later. Should be good for 2500lb. easy.
THIS IS THE WAY.....There are a couple of drop decks at Sunbelt in Okotoks, I have used one a couple of times now. I am fairly sure will be at the Calgary meet on Sat., so worst comes to worst, load it in my truck with fork lift. Unload at my shop later. Should be good for 2500lb. easy.
