Tool A couple of power files.
Tool
toglhot
just a Backyard Butcher.
I made these two power fies, to be used away from the shop where power is not available.
The first was made from a block of Delrin, but the motor was too underpowered. It worked but tended to get very hot.
The second was made from a lump of 10mm ally, using a bigger motor. Plenty of power but the motor spins too slow, it works ok, but would be better with a faster RPM motor.
Both can be powered from a car battery or a cordles drill battery.
Cool build, what motors did you use ? That second one looks almost like a blower motor
I gotta ask, what is the situation you find yourself in that you needed these ? I imagine there must be a specific use you built them for ?
