Brent H
@Susquatch : I hope I can make that call
I had a 3/4 hp on mine as well and no problems. I bought an new single phase motor and not being a motor guy I took it and the fwd/rev switch to a motor shop and had them wire it up. It cost me $70 but it worked and I didn't let the smoke out. If I had it to do again I'd have bought the VFD rather than the new single phase motor. You have the advantage of having the singe phase motor sitting on the shelf. I had the belt tension a bit loose so when I did stall the spindle the motor just spun the belt and didn't break anything.I think I'm going to try to swap this Baldor 3507L .75 HP reversible motor in for the 3ph thats there and see how it goes. the 1/3hp motor hoising is quite small by comparison so I'll update a new thread with any fitment issues.
@Susquatch - I don't know what brand switch is on your machine but the Allen/Bradley drum switch is easy. Contact 3 is the common, 4 is reverse and 1 is forward. Wire those contacts to the corresponding contacts on the VFD and away it goes. I still use all the machine gears but being able to tweak the speed with the VFD just adds so much to the functionality of the machine.
The fwd/rev switch should have a 3 wire setup, one being the common. The common and the fwd wire are connected when the swith is in fwd, the common and the rev wire are connected when in reverse. You should be able to determine whats what in the control cabinet pretty easily. You shouldn't need to mess with the switch at all.
You should see the big honkin switch on my SM1660...
If that Baldor isn't going simply drop in, I have a 3/4 HP single phase motor complete with new bearings and proper 4 step motor pulley installed that will sitting here collecting dust.
@phaxtristhe M in the circle is the motor, connected directly to the VFD, with nothing in between
I have one of these (1.5kw) on my lathe and after I upgraded to a 2hp motor I had to program the soft start to keep it from shutting off on start up. I’ve been meaning to get a higher rated one eventually.yea thats totally fair, i can tell you that these 2.2kw beige ones definitely do have it, i can even send you scans of the multi-page instruction set that lists all of the features etc if your considering. Im Fairley certain they are all reverse engineered from a couple different American made models, microprocessor code included.....we all know china isnt really into engineering their own products
I actually ordered myne from amazon, it was no cheaper than ali, and was at my door in a few days
I have a Teco VFD on my mill that works just as well but it doesn’t have a dial for frequency, which is nice.
That's odd. Both my TECO VFDs can be set to use the panel dial or an external dial for frequency.
Maybe you just need to dig a bit to find it.
