3D Printer Happened
If you want to save some money/space on a filament dryer, you can use the heated bed on your printer & a cardboard box instead. I did this and revived some old PLA I had neglected. Functionally, it's pretty much the same as a dedicated filament dryer.
Question: would it be worthwhile to throw some desiccant in the filament dryer (or printer heated bed) while it's drying?
This is the easiest, fastest DIY method to dry filament. It mirrors the open loop system I spoke about, heat and ventilation.
BUT, depending on the material it will cut the time you can actually print with your printer by 25 to 50%. That's a HUGE loss if you have a $500 to $1000 printer. 5 to 12 hrs to merely dry filament....
A cardboard box, an old hair dryer, an inkbird temperature controller and a rack to hold spools is cheap and easy. Hair dryer on lowest speed and heat plugged into inkbird.... temp control. Ported to you box... temp probe sensing outlet airflow.
addendum
I used a large tote, for both storage and drying, but I plan to make a separate drier that does not see heated airflow... I can smell that tote off gas and I don't like it.
Totes are great storage if they have a foam gasket sealing system... but they suck for active drying.
A heavy refrigerator box would be good. Something you can fit at least ten spools at a time, dry then store dry spools with desiccant packs
Desiccant is a protectant, not a cure.
Guide to pre-printing drying times
Well, that's no good. I had wanted a cure...... I don't want a filament dryer.
The article you linked is great! Lots of info there and some I didn't anticipate.
First I heard of molecular changes to the polymer itself......
Definitely need to keep things dry! Don't want the PLA degrading.
Adds new meaning to @PeterT's questions about printed parts!
Enjoyed the document very much John, but it isn't as clear as you are.
A cheapo kitchen hot plate comes to mind but I suspect the lowest 'warming' setting might be excessive vs optimal filament temp. Back when I was making longish composite parts, I made a hot box for resin tempering with regular incandescent light bulbs in an insulated foam coffin & little computer fan for circulating. I actually had to select low wattage bulbs & make some bleed holes to maintain 50-60C otherwise it would get too toasty. Those bulbs are old school replaced with efficient LED's but probably better/safer heat elements maybe with thermostat control. Probably reinventing the wheel here. What do the hobby / small business print farms use?
I was thinking an old chest freezer would be ideal because they're pretty much free. If you're good, you could even re-configure the compressor into a de-humidifier or a heat pump heater. You'd need the space for it though, and you'd need to print a lot to justify it.
Using the printer itself as a dryer works for me because I don't actually print all that much, I have enough printer downtime to dry whatever I need. I store my PLA in the open and only dry it when I see problems, usually run out the spool before that happens. Other filaments require more care.
I learned that you can't really 3d print without a dryer
I didn't get that from your earlier note. If I have to do it, then I have to do it.
Small two spool dryers are a hundred dollars. There are several that will dry high temp engineering materials. With a decent kitchen scale, you might even be able to sit the dryer on the scale to measure progress.
So basically a dryer to get the water out and dessicant to keep it out?
And a toaster oven to recondition dessicant.
You have a sealed printer chamber, I have an ender max, that originally hung spools on the side. I started out getting my filament exposed to too much moisture and had to dry.
If you're careful you can protect your filament carefully and not ever need drying. But it is so easy I just don't see why not.
Good conclusion here Peter thank you. A dryer speeds up drying of PLA from 4 weeks to 4-6 hours.
I have a really old spool of white PLA. I've noticed it can be brittle and breaks while feeding. If I dry it it then improves but it is not as good a new filament. So that to me confirms hydrolysis damage does happen.
Food dehydrators are a dime a dozen on FB markeplace or Kijiji.
Good temperature control and air flow. I can do 6 or 8 rolls in mine.
That would depend I’ve got a 34” waist so 6 / 8 rollers would be about 18 to 24 feet.
I’d like to stay silent but!
IMG_1974.jpegI
From now until April, Id do the same as we've been doing for 70 yrs with our wet winter boots n things....throw them on the house heating register overnight
They make an actual boot dryer- for rubber boots it's a game changer. It's literally just a small heating element and fan, exactly like a house register, I had a wood stove and then radiators so the house register wasn't an option for me
Dry boots in the morning, in winter.... no comparison
Im considering this. I'm a simple non-AMS guy so basically to dry & store so its ready for a print. There other similar ones, +/- reviews & price. Some of the ones that feed directly from the dryer into the filament lines have some shortcomings despite being on bearings. Anyone tried this one or very similar?
I used one of those Creality POS dryers for about 4 months, then the very cheap encoder/display failed. Now it takes several minutes of fiddling, thumping and cursing before it wakes up. The timer is completely shot, so it comes on randomly and turns off after a random interval.
It does still beep when finished though.
Sadly this seems to be a common them for many of them. Usually if I see like 6,000 5-star review & a couple % 1 or 2 stat I'll take a winger, but they so seem spotty quality by & large.
Bambu is a lot more expensive, like half the price of my A1 printer. But maybe worth buying once?
