Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The 2026 Calgary Area Meetup is set for Saturday May 30th at 10am. The signup thread is
here!
Robinhood has graciously offered to host the meetup again this year.
Please note that you MUST RSVP to the notice linked above if you wish to come.
The hydraulic drive would give you speed regulation and also an important ACCEL/DECEL when starting and stopping your gear engagement.
That slight speed change progressively loads the drive components and acts as a cushion.
I'm surprised that regular bolts work. They usually deform and often bugger up the system. Grade 5 bolts shear nice and clean and work much better. You might need 5/16 though because grade 5 is stronger than regular grade.
Depends on the Class of the bolt. We used to tow Aircraft in and out of the Hangars using a #10 size grade 5 (IIC) bolt as the shear pin in the system. Didn't keep any souvenirs, but am willing to swear to that it was a fairly basic, 3/16" bolt of no particular significance! We all carried a couple spares in our pockets!
