I have a 60gal air tank bought ~2006 from House of tools. Recently the ball valve started to leak (the lines pressurize over time with the valve 'closed'). I replace this yesterday.
While I had it off, I stuck my finger in the tank and fished around. It was 'damp' and had a rust residue -- which I anticipated given the time. I have one of those auto-moisture solenoids on this unit so it is bleeding water automatically.
The question: When would it be prudent to replace the tank? I've seen people replace it because of insufficient CFM, burned up motors.......
Assuming that the filter(s) upstream capture any particulate/moisture, is there concern? Or is the concern more corrosion/tank-failure (has anyone ever heard of a tank failing?)
