JimGnitecki
That makes sense. In high quality or closely regulated processes, this would be important in the event something later went wrong with the item(s) made with that material batch.As Mcgyver said HT is the heat number used to trace the composition of the steel. When I was working I had to order material for QA jobs and the HT # was required for tracing. We also required a copy of the mill certificate for our records. These numbers would then be written or stamped on all the material used for the job. It was used mostly on pipe. The info was recorded in a data base, along with date, QA number and PO #
Many years ago I had a friend who ran a Honeywell diagnostic laboratory that investigated a U.S. military jet's unexplained control surface failure in flight and subsequent crash. His team analyzed parts from the aircraft looking for fabrication or process anomalies. They found one. A piece with deviant metallurgy was identified, and was traced back to a specific heat treatment which was confirmed to have been done incorrectly.
Jim G
