The heads at this stage were cleaned & the valve cages installed using Loctite 680 HT retainer. Permanent installation is required at this point because the next step is to cross drill the port passages through the aluminum head & into the bronze cage. As you can see, the valve seats are cut. I...
www.homemodelenginemachinist.com
