Wanted: 4-3-2 step pulley w/ 1/2" bore
TorontoBuilder
The pulley on my vintage motor already has a bent flange and I'm likely to do more damage in getting it removed from the motor so I'll likely be needing a new pulley.
Any old vintage 3 step pulley with the major diameters of 4", 3" and 2", cast aluminum or iron should do the trick
I have one ,you can have if you can get someone to get to the Niagara area to pick up. I’ll double check that it is the correct size.
Martin
Edit 4-1/2”-2”-1/2” bore. It’s a four step
Martin
I appreciate that, but I'm unsure it will fit the length of shaft my motor has.
I have a slightly smaller 3-step pulley. Odd bore, but maybe it can be shimmed....
I also have a 1/2 in bore 4 step in my collection that I think pretty much includes those sizes or at least covers that range. "Major diameter" means "the outside of the flange"?
