I did the
@Susquatch quip because I agreed with your take of the HP/torque/RPM relationship made in previous comments.
Your point about the SLV or closed loop controlled drives is of course true as far as rotor RPM is concerned. My only point about the Slip topic is that Slip as a physical principal (being expressed as rotor RPM < EMF RPM) is always present in an AC motor with a non externally excited rotor.
So when it’s said that the motor doesn’t slow down, I mean maybe the rotor RPM doesn’t change, but if the drive were not compensating for that, it would slow down, and the slip would increase, and it is often imperceptible.
Even if the drive compensates for the slip, it does increase with increased load. That was my only point.
I’ve had a VFD on a 1970s drill press (3/4 hp, 6 pole motor is not VFD rated) for ~10 years. The VFD is an Allen Bradley, vintage the late ‘90s. Per comments above it is a low duty cycle. I had one job of tapping hundreds of holes and set the drive up for rapid reversal on a foot controlled switch. The torque for actual job (3mm spiral point tap on a through hole) was minor - the endless fwd - rev - fwd - rev - fwd …….. (you get the point) at about 25Hz (on my lowest belt speed) should have been a workout for the drive/motor. All good, no problem.
Advise I was given was to keep the motor leads as short as practical (the longer the motor leads, the greater the potential for harmonic issues?).
Increased lead length can lead to cable / motor impedance mismatch and cause transient high voltages capable of damaging motor insulation. This typically would happen on cables longer then 5m and would only cause damage on motors where the insulation rating is close to the peak to peak value of the source.
So at 230v on a dual 230/460 motor, you are almost under no risk of this causing issues unless your cable is crazy long (100m+).
On 480v applications…. Ya. Definitely could be a legitimate problem for you. With P2P values of 1350 ish normal…. Insulation only rated at 1500v….. not very much does it take to degrade insulation.
1500v insulation and 650 ish volt P2P you have a lot of wiggle room.
