UHMW
I'm more of a viewer than a film maker..
No sweat, I already created one in my mind for you. It features dogs running in all directions with their tails tucked between their legs, an overhead door with a big huge hole in it, a lathe doing a break dance around the floor, and you hiding behind a red shop rag on one leg.
I have no idea why you think a shop rag would protect you. But your dogs are clearly showing very high intelligence!
The dogs are smart enough to stay out of the shop.
When the piece got launched the first time it didn't go far. The second time it hit the wall and then ducked into a corner that is filled with galvanized pipe and chain link fence remnants built up over 20 years. The lathe stayed surprisingly stable. I did most of the dancing while trying to count fingers.
My experience with plastic is that the swarf tends to wrap around itself and stick there. Sometimes a mixture of dish detergent and water helps. The swarf still wraps up but does not stick to itself and is much easier to remove. Use a good amount of soap, until the mixture is slick.
