Former Member
Guest
In terms of setting tooling in ER holders I do it all off the mill.
I see. But can't you buy the ones that are missing from the set?
These is called Weldon mounts and NO! these actually cause less accurate cutting. Yes I use them for a few very specific cutters but overall have gone to several R8 heads with ER heads in them.
Getting carbide cutters with Weldon flats is difficult, unless you are using HSS, in which case, we you have lots flex any way so whats a little more.
Well.....sorry to burst your bubble,
Getting the Best Performance from ER Collet Chucks
Maximize the performance of ER Collet Chucks with essential tips on maintenance, cleaning, and proper assembly for better machining results.www.cnccookbook.com
I have read other articles on this, and it is generally geared toward CNC and spindle speeds as the increase and which holders not to use, Weldon being among the first because of lack of balance.
Don't believe everything you read....
Switching to an ER Collet holder completely smooth no more chatter.
2. The ER system uses a very long taper with contraction slots originating at alternate ends of the taper. This results in very even tightening of the six fingers across the whole length of the taper. This is a much tighter grip than most other kinds of holders.
ER collets have a significant place in machining as many here know, some guys here also know what the limitations are when using more aggressive endmills with them.
In the past, I sold Haimer shrink tooling and balancing equipment, don’t get me started on grip, stability and balancing.The End of the Weldon Holder Era
HAIMER, a member of Partners in THINC, offers the Safe-Lock system to provide pull out protection and many other advantages during high performance cutting.okuma.com
ANCA CNC Machines | Industry-Leading Tool Grinding Solutions - ANCA - CNC Machines
Explore ANCA’s world-class CNC tool grinders, automation systems and software. Trusted by tool manufacturers for precision, reliability and innovation.machines.anca.com
How to Choose the Best Toolholding System for Your Shop
Many job shops hold onto traditional, inexpensive tooling systems. ER collets and Weldon flats are tried and true; they work and are proven. At the same time, newer, advanced machining technology, such as multi-axis machines, may perform better when newer, advanced (and more expensive)...www.sme.org
Again understanding why and why not to is important.
I have a Weldon (other than for Annular cutter) a10mm unit, run out is fine, but I found that when run at top speed on my mill 3700rpm it had vibration, HS was worse than Carbide. Switching to an ER Collet holder completely smooth no more chatter.
When I read, I generally check various sources as we all know internet information can be somewhat suspect at the best of times.
Last, but not least, one needs to ask if true concentricity is really important in milling.
Firstly, let me say that if you get any runout on an end mill at all, it is never a problem for a skilled mill hand. It might bother a novice, however.I have a Weldon (other than for Annular cutter) a10mm unit, run out is fine, but I found that when run at top speed on my mill 3700rpm it had vibration, HS was worse than Carbide. Switching to an ER Collet holder completely smooth no more chatter.
Actually I'd like to hear your experiences. I'll never own shrink fit tooling, hell the heating machines are $5k-70k!!,In the past, I sold Haimer shrink tooling and balancing equipment, don’t get me started on grip, stability and balancing.
There is place for the technology when certain objectives need to be met. Shrink tooling is ubiquitous now and requires in some cases merely a hand held heat gun. I’ve had 1/2 carbide endmills pull out of a shrink holder as well. It is great for high speed finishing where runout matters, contouring and light roughing with small diameters in high speed spindles.Actually I'd like to hear your experiences. I'll never own shrink fit tooling, hell the heating machines are $5k-70k!!,
But I'd like to learn about the process from machinests vs manufacturers.
It was nearly new, just the wrong endmill doing an inappropriate roughing pass in difficult material, prehardened P20 , tenuous at best, put it in hydraulic Chuck and carried on, inappropriately but successfully.Your expertise in tooling is bang on... Although, I wouldn't settle with a hand held heat gun for shrink fitting lol, but I get it...
My 2 questions would be...
1) Do you know how many 1/2 endmills went through that holder prior to pulling out?
2) Do you know approximately how many times you can use a shrink fit holder before tossing it in the scrap bin?
Thanks!
Hundreds of times if using the proper induction machine correctly. Once if you overheat it because someone said you can use a torch, because they said a buddy does it all the time.
Real world is different from the parameters used in the lab when testing the holders. That reason is why I say hundreds rather than the thousands as Haimer can claim in their testing.Ok, I don't plan on using a torch lol.
I'm having good luck with the PC409-I41-C21 with A2-D2 hardened sections with good tool life.
Using the OSG exo-carb line-up.
However, they mentioned after 20 heat cycles or so, the holders should be replaced, "should meaning" I shouldn't go much beyond 20 unless I clean them up and check, although I will check quite often now. Which I can live with but...
So for the heck of it, I cycled a 3/6 long reach holder, using an exo-carb 3/16 ball, several times over the period of several days... I found after 18 cycles the holder was ready for the bin. I haven't tried this with the 1/2 " holders yet...
I see no possible way at this point to get hundreds of cycles out of a holder when I couldn't get to 20.
Perhaps I need to look into different holders?
Thanks.
I saw an article and one of the developments with climb cutting was bit pull out, it has to do with how the bit flexes, grips and slips (yes even shrink holders do slip). I believe one of the methods to prevent this is that some manufactures have added counter spirals ground into the bit shank to drive it in if and when it occurs.Your expertise in tooling is bang on... Although, I wouldn't settle with a hand held heat gun for shrink fitting lol, but I get it...
Thanks!
