Today's project
ShawnR
I have one of these (similar to) on my electronics bench
https://www.globalindustrial.ca/p/o...dYwdXBl8BK30e4nHfuQcqmZtV2tn7ShhoCgjMQAvD_BwE
Where the light assembly attaches to the upper arm, there is a split bushing/friction lock/insert that is probably cast aluminum and has broke. I glued it back together to take measurements but looks like it will be the project de jour
Roughly 1 inch wide by 7/8" tall by 1/4" thick (each part)
That will keep you busy. I have a similar mag lamp, also on my electronics test bench. I keep meaning to replace it with an LED model, but I have two replacment round fluorescents for it, still unboxed. So unless I find a great deal, it's old school for me for a while longer.
I should have started on it when I went to the shop this morning,..but got sidetracked. So today's project might become tomorrow's...
Almost done. But close enough for posting purposes. Looks like they will work. I am not sure about "texturing" for locking the lamp in various positions but I figure if it needs something, I might put a knurl on it or insert rubber gasket/washer/disc. A bit of fit and trial to do tomorrow. Honestly, no need for a mill on this one. I roughed them out on the bandsaw, milled to the traced scribed line (mostly cause I wanted an excuse to use the mill), then finished with a file and sanding disc. Having said that, The mill, being used as a rigid accurate drill press, was good for drilling the hole (concave feature which is a pivot point). I never took a picture but I clamped the two old pieces together, (after gluing them back together to get better dimensions) determined that a 5/16" bit would cut both halves nicely if bolted together, then did as much of it as I could with a 5/16 2 flute end mill. When I ran out of cutter length, I finished with a 5/16 drill bit but at least I had a good guide by then.
I am hoping the brass stands up better than the aluminum as I only got about 8 years out of that.....:rolleyes: ;)
As an aside, I see the CAD thread running. I have wanted to learn CAD for years and started many times but usually/always gave up. Working from drawings like that is really nice to do, but for the stuff I do, a napkin is more efficient. Lately though, I have been sketching stuff up in Paint, even if just to the point where I can write the dimensions on later or in the shop. I find the dimension lines are a pita to do sometimes. The drawing can be fun. So I threw that pic in here as well. Someday, I hope to concentrate on learning a CAD program. I will follow that thread.
Happy Superbowl day! (Not a huge football follower but I like the food associated with the game....)
Cheers,
Shawn
