To coolant or not to coolant.
Dumb question, what's the distinction between coolant and other cutting fluids? From the name I assume it keeps the material and tool temps down better, but when is what best used? (Eg: in my case, say drilling out plastic - "coolant" vs the tap magic aqueos I use, or more generic cutting oils)
Coolant is water soluble, usually 1/2 cup of oil to 5 gallon pail of water. Makes large quantities and very fluid for flushing chips away as well as cooling.
Cutting oil is thicker and usually applied manually. It sticks to the part and cutting tool.
I buy coolant by the pail, roughly 150$ to 200$ for 5 gallons.
One gallon of rapid tap is 150$.
Thank you!
I'm to the point of squeezing the last few cc's of cutting oil out of the gallon jug of Rapid Tap and am flabbergasted at the price for a replacement jug. (Lower island group buy ?)
My mill has a coolant setup, not installed yet and the Meuser could be set up reasonably easily for coolant as well (dangerous statement ?). The surface grinder is set up and I do use coolant on it perhaps 20% of the time.
My concern is that I'm a slob. I'll often leave an unfinished job set up at the end of the day and between jobs it is too often just a quick brush off of the mounting surfaces and go. My fear with coolant is that my sloviness will lead to unwanted issues that my machines don't deserve. I know the simple answer is to show my tools their due respect and clean them properly at the end of each day. Tried that but it's me we're talking about here, doesn't work. So how valid is my concern and are there any tricks or hacks to help alleviate my shortcomings ?
I have been an on and off and back on again coolant user. My home brew CNC conversion I used coolant with and learned to hate it enough that I switched to a "fogbuster" type setup. Sold that mill when I got the Tormach that had a full enclosure with flood coolant and I've been running it with coolant for about 2 years now - in a very infrequent manner. Its been ok. The big thing was adding the fish tank bubbler AND a timer that runs the bubbler only 5 mins 4 times a day. I haven't had issues with corrosion and I'm pretty lazy with cleaning up after, leave the vise on the table etc. If you don't have an enclosure for containment though, I don't recommend. Cleaning coolant off the floor is not the chore I enjoy, and I have to do that once in awhile when I spill it or the enclosure springs a leak.
Regarding the squeeze bottles. The Amazon specials that I purchased leak like a sieve when inverted. Even the “high quality no leaks” ones.
The up and over then bends down gooseneck style are the only ones that I have that you can actually use without getting an equal amount of fluid on the destination and your hands.
Thanks for all the comments, I feel more comfortable NOT setting up coolant and continuing on dabbling oil onto my work pieces from my YotaBota spill proof oiler.
Checking around again on prices for Rapid Tap I was a little disappointed that there appears to be no 5 gallon money saving options. KMS seems to be the winner at $86 /gallon ($12.95 for 14 oz), $10 more than my last bottle.
I also found an offer on Amazon for $346 plus $36 shipping with prime for 14 oz, perhaps arriving in time for Christmas.
As such Mike and John I don't see any group buy.
I bought the best part of a 4L jug of ridgid cutting oil a couple of years back. Still have most of it.
Since i have an Atlas MFC in the project list, and they used to have the little drip fluid setup :
Was just wondering if anybody still does it this way for some things? I've seen some setups just pumping cutting oil all over the cut and tool but I rarely if ever see the need for oil except when taking a finishing pass. . . rough dry, finish wet kind of philosophy.
I've known a couple of people that have home made setups like this. If you look at the Deckel FP page on Tony's site you can see a similar gravity lubrication setup on some of their very early mills.
I made a similar but much cheaper version of this one. It worked ok. But I pulled it apart to fix leaks in it and never got it back together. I 3d printed a couple of the parts, they were not the correct plastic as the got sticky. Used a cheap mag mount from amazon, a plastic pop bottle, a little on/off valve and the little cheap amazon line lock to move over the cutter. I may put it back together and have another got at it as I have some better parts. Also after finding the aluminum baking trays that fit really well on the lathe makes this less of the mess it was originally.
I think that the most basic definition is that coolent is designed to cool the work / cutter. So it is some fluid with a high specific heat capacity like water
And cutting fluid is designed to ease the work of the cutting by providing an interface layer in the fluid phase. Thin film properties dominate, and on metal the obvious example is hydrocarbon fluids (oil)
I think any practical fluid has significant overlap between the two
