KeeponDragon
no problems... just challenges
So I finally got the courage to attempt some kind of operations with the TA my centenarian came with.
After giving the attachment a good clean and scrape with a razor blade, I figured out what to do in order to set the angle of the dangle...that was the easy part.
First thing that confused the hell out of me was...why isn't the crossfeed screw turning...
After a little google-fu and one video from Abom79...my worries about something being jammed or getting broken were put to rest...
And now...behold...my first attempt in learning...
This was a bushing pin from a 40 ton rated Hendrickson suspension. It already had a taper on it. So I used it as a guide to setup the operation.
The rust band you see is where the threads stopped.
YouTube link to see it in action
