Surface Plate Marketplace Find
WRebuild
Active Member
I've been casually searching for a granite surface plate that was reasonably priced for my needs. I had been considering a few brand new 2' x 3' surface plates, but I hesitated to opt for a cheaper Grade B quality. However, last week I stumbled upon this awesome find on Marketplace that I couldn't resist. It's a massive 10-inch thick plate, and although I wasn't initially aware of the brand, upon inspection, it turned out to be a Starrett Grade AA—a delightful surprise! Now, I'm thrilled with my purchase and eager to set it up, give it a thorough cleaning, and after resting for a few weeks I will check its true flatness.
For those curious, the plate measures 38" x 65" x 10" and likely weighs around 3000lbs, more or less.
Do any of you also work with surface plates? Any suggestions for removing light stains from the sides during cleaning?
Granite Surface Plate Cleaning
Suburban Tool also has some good videos about setting up and checking for flatness.
Oh, and @Susquatch is correct!
Thank you so much! I will definitely look into this video and collect some ideas. It's larger and heavier than I actually need it to be, but I'm not complaining 😀
It probably says “ This end up “.
Yup. Made in Egypt by union members - the united granite workers of the ancient world. GVW 250 metric tons. Fragile do not drop. Twenty five hundred people required to move safely. And of course 42. 😎
