TorontoBuilder
Sapientia et Doctrina Stabilitas
So I wish to solicit opinions because I have little experience with sheet metal assemblies for structural purposes, and I don't want to be this guy.
I need to make a bracket that will hold a lathe countershaft. The shaft will be mounted in two pillow blocks. The shaft will suffer bending forces due to the opposing loads that the assembly must have sufficient lateral rigidity to resist. I hope I used the right terms.
The rear of the shaft will have a timing pulley and belt that goes to a motor slung beneath this bracket and the heavy duty 1/2" thick cast iron bracket it shall sit on. The near side of the shaft will have a dual vee pulley and belt going to the spindle mounted in the head stock above.
Below is am image of the main heavy duty bracket and the ghost image of where the variator normally mounts. My bracket is to replace the variator and hold a new shaft at the same centerline height.
So, after being publicly shamed for proposing having a part made instead of taking the DIY approach (I'm not really complaining because I am both cheap, and I prefer the DIY approach) I think I can actually fabricate this part with the resources I have at my disposal... which are, metal band saws, mig welder, nibbler that can cut 12 gauge carbon steel sheet, and a box bender. Maybe just maybe I could manage 10 gauge.
So my questions are these... will 12 gauge sheet be rigid enough with just a simple top hat shaped bend as show? Or failing that, will 12 gauge sheet steel work if I welded in two gusset plates on the underside of the bracket and perhaps doubled up the thickness of the flange by welding another strip of 12 gauge on top of the flanges?
I wish i had access to a heavy duty spot welder so I could do more sheet metal work because I can think of a thousand projects to do
