I'm looking for a small'ish spring. Not having much luck in Canada.
This is the specs of the recommended spring and the closest I've found.
This is for a boost bypass valve so the spring rate is partly what determines when it opens.
Anyone know a good CDN supplier?
| Spec'ed spring | What I found | |
| Wire diameter | .762mm | .8 |
| Small diameter | 12.7mm | 12mm |
| Large diameter | 16.3mm | 20mm |
| Free length | 28.7mm | 30mm |
| Spring rate | .80 lb/in | unknown |
| Material | 302 stainless | 304 stainless |
