Speed handle on the cheap
YotaBota
Mike
Not even inexpensive, just really cheap. I've been looking (not hard) for a speed handle since I got the mill and haven't found one. The other day I was in PA and they had 3/4 inch tire irons for a couple of bucks each, the light bulb came on and I bought three of them.
To get a deep socket I cut off two of the socket ends, face them and chamfer one end of each and welded them together making a deep socket. I had to file the inside of the socket a bit where I blew thru a bit when welding to get a smooth fit.
I cut the handles off leaving about ten inches before the bend and about two inches after the bend. Made a quick wooden jig and welded the short legs to the socket.
A little cleanup and a coat of paint and viola, speed handle ala cheap.
The legs main be a bit long but they'll be easy to shorten if needed.
CalgaryPT
You likely know this already but some heavy duty shrink wrap on those handle ends add some functionality and a nice look :)
Great job.
YotaBota
Mike
It was a good way to spend the afternoon.
I have some of that liquid rubber use on the handles, or I might have to build one of those ball making jigs for the lathe.
What do people do without toys,,,,, I mean tools. lol
CalgaryPT
Those are two even better ideas. Good for you.
