Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
I feel your pain. When my SB9 starts spinning up that 4" 3 jaw, stand back...One look at that and it becomes instantly clear why lathes can benefit from a bigger motor with a VFD to control the acceleration rate.
Yup- it's an 18x48 lathe ....just the thing for a hobbyist with a crane for changing chucks!Look at that face plate on the floor leaning against it.......
That's not much bigger than my 12 x 36. (and then I looked at the picture)Yup- it's an 18x48 lathe ....just the thing for a hobbyist with a crane for changing chucks!![]()
I bet that lathe has a clutch… that was the mechanical engineering solution for those problems.Just imagine the forces on the motor and gear train spinning that thing up......
Once you have used a lathe with a clutch, you just don’t want to use one without. (I guess a VFD controlled one comes close - and without the extra complexity of adjusting the mechanical clutch. That is a bonus.)
For threading, the half nuts stay engaged, the spindle stays running, and you just stop the feed at the end of the cut and reverse the feed back to the start of the thread, advance the tool and start the feed. No thread dial to look at.
No idea about the Lang (or even if it for sure if it has one , likely), but my DSG has an Matrix wet plate clutch, top drawer stuff. At 55 years old its almost broken inIm guessing its a single tooth dog clutch. It never loses sync. I've screwed up with a threading dial before, so this is so much better. You don't have to think about it at all
100% agree if owners take even a little care of the clutch by setting them up properly, they will last a very long time. Örtlinghaus and Baruffaldi are synonymous with Matrix for top of the line quality clutches and brakes for machines.my DSG has an Matrix wet plate clutch, top drawer stuff. At 55 years old its almost broken in.
And that has just given me a idea for a great feature for my electronic gearing. It currently has an interlock to stop changing anything while under power, but being able to reverse the carriage and come back into the right spindle alignment wouldn't even be difficult.For threading, the half nuts stay engaged, the spindle stays running, and you just stop the feed at the end of the cut and reverse the feed back to the start of the thread,
