Some knives
I have seen a couple made from power saw chain.
Yeah, many people forge blades out of saw blades, chain, leaf springs, and other mechanical parts or tools because they are made of alloy high carbon steels that either have high toughness like leaf springs, or high hardness/hardenability like saw blades.
I have some old logging mill saw blades that I got from a distant relative. They are large wide bandsaw blades, so they are already flat, but they would require full annealing and normalizing in order to restore them for proper heat treatment to use for a knife or sword.
Thats an awesome idea! I've been using my heavy vice for plate quenching and the plates shift quite a bit. I have lots of spare drill press vices that I could fasten the plates to instead.
I went and ordered a new toaster oven. Yeah, I should've waited to find something second hand, but to me the value of not having facebook in my life is greater than the extra $ I paid by getting a new machine. Still, it was under $100 and will toast 6 whole slices of bread! I can temper up to about 40cm depending on width.
Also on order is a pid and associated parts I'll need to convert this oven. Austenitizing temperature is definitely critical, but so is tempering temperature. My kiln isn't great for tempering, although it'll have to do when it comes to long blades, and the toaster oven I currently use sees double duty as a leather waxing oven which doesn't need no fancy pid since it doesn't go above 80C or so.
So, finally, a dedicated and highly accurate tempering oven is in my immediate future. That will round out my heat treating situation nicely, and allow me to squeeze all the high performance out of today's super steels that I can.
