Sight glass help
I’m refreshing my late 1970’s Luxcut 1136 lathe including full disassembly and fresh paint.
On disassembling the carriage assembly the oil sight glass fell into 3 pieces on me.
This is a Taiwanese lathe and it uses a push in style sight glass with the small dimension of 19mm, and the larger size recess of 24mm.
I’ve been cruising online and I can’t seem to find a sight glass in that size at all.
Any suggestions on where I might find one in that size? Or any other options?
check out this post for some discussion
The other alternative is to get cast Acrylic sheet/plate the appropriate thickness, cut out a square and pressure turn the OD & shoulder.
I made a similar sight glass for a government surplus lathe this way a little over 50 years ago.
Make a couple while you are at it.
if it is just a flat round glass you are looking for check out watch crystals.
For my monarch lathe I ordered 2mm x 23.9mm round mineral crystal. They were only a couple of bucks each. I think I have extras still if it works for you.
