Show us your shops!
Any issue with having to shim equipments or anything from having sloped floor towards drains? I'm thinking of adding two drains but also don't love the idea of losing a flat and level floor and a possible working surface. I won't have cars in here and motorcycles will be washed outside.
My shop and garage floors are all perfectly level. I HATE THEM. I wish they had put a very very small slope in. Just enough slope so any puddles from leaks, snowmelt, or rain fall didn't creep across the floor, under machines, or or or. I'd be aiming at something like 1/4 to 3/8" per 10 or 12 feet. Your machines will never know the difference but your happiness will.
The biggest problem in my shop is the big vehicle doors. When the rain hits them, it runs down the door to the concrete ledge where the pressure drop drives it under the door where it pools into my shop totally out of control. I have old towels and soak tubes behind the doors but it's never enough.
The next biggest problem is snow melt. Again, it goes everywhere and I hate it! More towels and more soak masters.
FK FK FK FK FK!!!
Water WILL FIND IT'S LEVEL. If you don't give it a slope to crawl on, it will crawl where you don't want it. Fk.
And it isn't just rain! It's also leaks, spills, and even coffee! I dont want that crap going wherever it wants. Give me a controlled slope all day everyday!
I always said if I were to ever build a new garage/shop that I would have a floor drain in it. I hate water running to the walls and underneath everything. Wel I had a new shop built a few years ago and had a floor drain put in it. I only had the floor sloped on half of the floor to a central floor drain. I was concerned about having level floor for machinery. I now wish I had sloped 2/3 of the floor. However I believe even if I had the whole area sloped, machinery could have been adjusted/shimmed to level very easily as the slope is just noticeable.
1/2” per foot slope in wood shop/welding shop/ garage here. A little hard on the back, but water doesn’t pool, and had to loose some height to meet driveway anyways. Chose to make machine shop walled off end of shop level. Hasn’t been a problem. About concrete in machine shop, industrial epoxy after deep acid etch, and a tiny amount of sand thrown on top when epoxy was wet. Twenty years later it’s working well with only a little wear.
HOLY CRAP! That's like 5" in 10ft! Practically a curb! I'd be afraid of stubbing my toes!
Heck, even field tile is only 3/4" per 100' around here. I know some places are up to 3" per hundred. But even that is only 30 thou per foot.
Yes, but no pooling water. 😎
I would have been happy with 1/4” per foot, but like I said, had to loose some height due to site requirements.
Just keep in mind, can you get water out if it does end up in the shop? It does not all have to be sloped, perhaps just a bit towards a drain or some slope towards a garage door.
I have not seen a concrete floor that did not some slightly low or high spots in them. Not talking great amounts, maybe +/- 1/4 inch, one reason why some equipment has grout/shims between floor and equipment bases.
I suppose there may be level floors put in with lasers and automated equipment, but little out of the ordinary back door hobbyists ability, and many of the contractors, LOL.
I am not talking trying to control the great flood here, just as has been said, control where it goes. In my case the walls are on footings/out side walls, that are above the floor level. Under the garage doors, there is a steeper slope and a step just outside the door of about one inch down to the apron, all in an effort to stop/control water/rain from blowing in under the door seal?? when closed. Water WILL move up slope when the wind push’s it.
.5in./foot, could make you into a side hill goer, on leg longer then the other, LOL.
Exactly. When it rains in this country it often comes with a wind and unfortunately my man door is faced into that wind. My door swings in and I cannot get my door sealed well enough on the bottom. I don't want to put a big tripping hazard threshold up against the bottom outside of the door but I think it would help with water penetration.
1/4" per TEN feet would be totally adequate!
I've been thinking about getting the concrete under my doors beveled.
Who is the guy who’s complaining about water on his floors? T’aint me! ;-)
I am. But that's because the guy who built my shop wanted it dead level. Idiot!
There is a lot of territory between dead level and the Rocky Mountains. I don't want either one. But if you are happy climbing mountains, I am happy for you.
I don’t worry about slope the way the ground shifts here the cracks in the cement takes up the slack even the sidewalk tile has dropped about 3/4 of an inch. I blame it on the city’s alleyway being down so low that driving a car into it scrapes the bottom of the car.
