@ShawnR I designed a hydraulic press for a friend in the early 80s, and yield strength is a small part of the design process. Predictable deformation at the maximum load is also a factor.
For a 10 ton 36" span Hydraulic press I specified a table beam made out of 2 pcs of 6" X 1/2" solid bar, with spacers welded to prevent local deformation under load. This was the lightest that would work, and it still will deform more than he specified under 10 ton load. My vague recollection was that at 10 tons with 36" pin spacing, it would deform about ,060 under 10 tons. to get to his .030 desired deflection, we would have needed a 9" depth and more webs welded in place.
thr problem with deflection is that 'bumping' you hear when the object suddenly moves, and that movement reduces the pressure as the table is acting like a big flat spring.
So over-design the table by several times the material and double the depth if you want a press that is both easy to use and works well. This is why industrial presses have a hand winch to raisle and lower the table...
