Sharpening large drill bits?
slow-poke
I use a Drill Doctor for small bits. For larger bits I need to hone my drill sharpening skills. I only have one grinder at the moment and the wheel has a very coarse grit. Seems like I should start with a smaller grit wheel. I actually have an older but good white much finer grit wheel so I think that is probably a good wheel to try? Comments?
I just watched a sharpening video at it seemed like the grinder was turning at a much slower speed, total guess but looked like < 1000 RPM vs. my 3600RPM, since I need to get or make a grinder for this white wheel is there an ideal RPM for sharpening?
What about fixtures to maintain the correct angle, unnecessary or a good idea?
I definitely need some pointers. Thanks in advance.
How big do you go?
Speed is determined by the diameter of the wheel for optimal SFM. So 3600 rpm is great for 6" and 1800 rpm is a bit slow for 10" - 1800 rpm is SLOW for 8"
For drill bit sharpening you need soft wheel - i.e. it needs to fall apart easily to expose sharp pieces.
I frequently sharpen by hand larger drill bits on a belt grinder.
Up to about 3/4 or so I use 6" grinder. Touchup up to 3" is on belt. I have no experience above that size.
I also have home build device to sharpen drill bits on a TC&G.
I have a gauge to make sure the angle is correct and it is important that both cutting edges are the same length.
I find big drill bits are easier to sharpen than small ones.
I have a 8" grinder with a white medium wheel for sharpening high speed steel and a 6" grinder with a fine white wheel for finishing the grind. Both run at 3450 rpm.
I use a stone and a diamond file on smaller bits.
The size range you are talking about is perfect for hand grinding. Not too big, not too small. Get a drill point gage for checking angle and width of cutting edges. It's a skill definitely worth learning. It teaches you the basics of cutting edge and drill point geometry in a way you will never learn with specialized grinders and jigs. I've recently been thinning the web of #27 drills free-hand on the corner of a grinding wheel with surprisingly good results.
great advice. I'm gonna go buy a drill gauge.
The included angle of the tip is not really super critical, 110 deg, 118deg heck 140 degrees all will drill, what is really important is the support behind the cutting edge, to steep it will drill like a banshee for about 2 holes before chipping or dulling, to shallow and it either doesn't drill at all or takes a massive amount of pressure
Take a look the side of the cutting lip of some factory bits, try to emulate that angle, being able to get that right is what separates a good sharpen from a bad one, a long lasting shapen to a 2 hole wonder
Once you get the hang of it you can modify the included angle and support angles to suit the material you are drilling
Edit: a note about both cutting edges being equal, it will drill if they are unequal, the bit will just wander and not drill a straight hole, best to make them as even as possible
Bit sharpening is not that difficult with practice and a steady hand.
Start with a good quality (80 grit, brand name like Norton) medium grit balanced wheel. Decide if you want 118 angle (general purpose) or 135 angle (harder metals). A bit gauge is a big help. A balanced wheel is very important.
Here is a set up to balance the wheel:IMG_3002.jpegIMG_3001.jpegHere is using a diamond single point cutter (in a jig) to make the wheel round:IMG_3018.jpegAlso should check that the two bit corners are engaging the work evenly. IMG_3157.jpegHere is a couple samples of 3/8”hand sharpened bits (as others said, bigger bits (over 1/2”) are easier to hand sharpen).
