I have a little 4x36" belt bench sander with the circular disc. It has a little motor - it works fine for what it is. It's slow and I can stall it pretty easily. It would be nice if it was more powerful. It was $40 used I think... Similar to: https://www.kmstools.com/king-canada-4-x-36-belt-6-disc-sander-117779
I want to take mill scale off in a hurry, handle burrs, and shape parts. The usual. I also find trying to sand the inside of corners there is not enough clearance to get in there.
You can get this new combination at Busy bee for $399, 1HP motor (Chinese), 6" x 49" belt and the disc. Similar to what I have but bigger.
https://www.busybeetools.com/products/belt-and-disc-sander-6-x-9-craftex-cx.html
Similar is this from King Canada 1HP for $469
https://www.kmstools.com/king-canada-6-x-48-belt-disc-sander-5767
There is this King Industrial at KMS 3" x 79" belt 2HP 220V 10Amp. $950 A metal working product not wood repurposed. Looks good. not a very wide belt.
https://www.kmstools.com/king-industrial-3-x-79-metal-belt-sander-141967
@CalgaryPT Peter I believe has a kalamazoo maybe similar to this one 20" disc sander. Very fancy. $3K USD
https://www.trick-tools.com/Kalamazoo-20-inch-Disc-Grinder-DS20-10370
Anybody have any thoughts? is variable speed useful? what about the clearance problem into corners? are zirconium belts a problem to source? I've never found the round disc useful and it tends to rattle so I took it off. Why do you want a belt vs a disc?
