Royal Live Centre Bearing Replacement
My Royal Versa-turn precision (half a tenth) live center has a brinelled bearing in it so I need to take it and Rep ace the bearings. Here is a blowup I saw on Royal's Website.
I'm thinking I'll drill a hole through the shank so I have something to pull it apart with.
A Royal Versa-Turn 4MT sells for $1,765.73 at KBC!!
I'm pretty sure that the factory doesn't drill holes in the unit during servicing. We will figure out how to disassemble it.
The factory claims it isn't serviceable.
They likely pressed it together.
Mine is MT3. I bought it used.
I'm all ears about any suggestions for taking it apart.
Here's a YouTube video on it.
Seems he just used a dead blow hammer to tap the head off. I'm leery of that. I'll try it, but with an abundance of caution and gentility.
As you suggested in our txt exchange, I'll heat the head, and cool the shank first.
If that doesn't work I might make a fixture to hold the head while I drop the assembly. The inertia of the shank should pull it apart. Sort of like a Lyman Bullet Puller.
If all else fails, I'll drill and tap the shank so I can pull it apart against a shoulder for the head.
Just thinking out loud...if you stick the unit in the freezer overnight, once you take it out, it's going to start to condensate and might make it difficult for you to hold onto it.?
Temperature differential may have even been how it was assembled but that doesn't necessarily mean the process is reversible. A freeze would give the assembly a contraction head start & you have the mass of the center arbor working for you holding low temp at the core for a bit, but not for very long. Feezer's are only typically about -18C so you aren't getting a lot of temperature differential compared to the elevated temperature / variation of a torch or heat gun, say 200C just as a number. Ideally we want heat applied near instantly to the whole OD to expand the case, but not transmit into the 3 bearings very quickly. Thats the challenge. Otherwise bearings expand at the same rate as the case = no net temp differential gain = same degree of interference fit. Temp might also cook the races/seals depending on what they used. A heat gun has the advantage of a setting temp but disadvantage of lower heat output. A torch has more output but more user variation. Worth a try but do a dry run so everything is in position. Too bad the end of arbor taper wasn't threaded so you could at least one end is retained.
I would not plan to freeze the assembly. Rather, I would apply liquid freon, or liquid propane, or this fast freeze stuff I have to find electronic intermittents, to the shank after heating the head. The head will not be heated anywhere near the ignition temperature. Just hot to the touch. I'm guessing that it will fall out right about then.
Ah, much better plan. A 'chilling' idea
Wife went to town. Time for the old tom cat to play.
My Royal Live Center is apart.
The deadblow didn't touch it.
I put it into the appropriate size black pipe and dropped it 2 inches - same idea as a Lyman bullet Puller. Nothing. The pipe below is just leaning on my vise for the photo op.
Heated the head with a hot air gun then cooled the MT3 arbour with some cold water, and tried again. It moved. A dozen more drops in a row and it was out.
I confess that I'm shocked that there is no thrust bearing.
Now I need to pull the bearings and see if I can find replacements.
Time to remove the bearings.
I'm sure glad they stayed on the anvil. I would have had to make a custom collet to get them out of the head.
As it is, the normal methods didn't work. Had to use my 5 ton bearing splitter removing one at a time. The center didn't fit the bearing center either so I used my lathe to turn and part a grade 8 screw to fit.
Bearings are off.
ID of the bearing is. 472 (11.96mm) measured with a precision pin. Corresponding Shaft is 11.99.
OD is 1.258 (31.97mm)
Thickness of all three bearings is almost the same at 9.94, 9.95 & 9.96 not sure why they vary but I don't think it's important.
There are no markings on the two unshielded bearings.The shield on the inner most bearing says: TJB F 6201-RZ Go figure.
Only the innermost bearing is shielded. No idea why. I'd have shielded the outermost one.
Now to source replacement bearings.
I google, the TJB F 6201-RZ and it looks to be readily available.
Interesting they didn't use a thrust bearing and instead used this deep groove bearing type. I will keep that type of bearing in mind if ever the application arise.
I have not put my google goggles on yet. Maybe later today.
Even if these bearings are reasonably adequate, I can still say they are not perfect. They brinelled when a big parting job went south. Yes, I know I should have taken my good center out before parting and used a lower quality center for that, but I wasn't thinking. Nonetheless, it shouldn't have done that to the bearing. A proper thrust bearing might have survived.
The other thing is why the center bearing? It doesn't do anything for the assembly. A bushing would have been fine. I'm not expecting the final repair to be as good as the original though.
I finally wrapped up this project. I'll never reach @David's project completion rate, but I don't feel I have to. Old age has its perks.
I wasn't making any progress finding better bearings for the live center, so I decided to put it together with the bearings I was able to find.
It isn't as good as it used to be which was less than 0.0001 runout, but it's prolly plenty good enough at 0.00021 to 0.00025 max depending on how much I load it. I have another good live center anyway.
At least now I can cross something off my list and move on to other projects.
Millwrights change bearings, that is our bread and butter. Thrust bearings wouldn't have as much lateral resistance as the very simple deep groove 62xx. That is likely one of the whys of the fairly light duty construction. The short distance and a the sloppy thrust bearing would degrade your precision would be the other. The only difference a certified bearing has over it's uncertified brothers is that it has been pulled off the line and tested. I got that gem from a poster who worked at Timken. When I replaced my headstock bearings ,I bought ordinary Timkens. On one machine I got tired of replacing deep groove 62xx and so I replaced one of the two with a 72xx, a thrust bearing. The 62xx were being pushed apart when they were clamping the spindle. On a different machine, I simply cut down the crank handle.
