In the dawn of time, I had a 6" RT. I had a job that I just couldn't clamp onto it, no matter what, so I built a 10"X10" fixture plate for it - it had 4 keys to tightly fit the "X" T-slots... It was made of 5/8 2024 aluminum, and it had custom holes drilled and threaded for the job. I had to round the corners, because they interfered with my column on that small mill, so I took perhaps an inch off of each one.
What characteristics would I choose for a 'topper plate' for a rotary table?
- I prefer square fixture plates for the extra clamping area in the corners, but it requires more clearance.
- Your overhang can't be too outrageous. The bigger the plate, the thicker it has to be.
- I like aluminum for the plate, noting it is getting expensive...
- Ideally, it would have a pattern of threaded holes and reamed holes like any other fixture plate.
- If it is big enough you can use your step blocks from your clamping kit.
- the perfect clamping arrangement is short clamps with a threaded hole at the non clamping end
(this is for a riser made from ready rod, so you can choose a custom size for the job)
- some guys prefer a locating hole in the centre. I locate the table before putting the plate on.
My perfect plate?
12"X12"X1" thick 6061 aluminum.
A 1" grid of threaded holes, except for the centre.
In the centre, a reamed 1/4" hole for a centre pin.
Interspersed with reamed 1/4" holes for locating pins.
Bolted in keys to locate the pate in the T slots.
My perfect plate?
