RAMoynihan
I found a 3 phase motor locally on Kijiji and bought a surplus VFD on EBay. This thread will document the process of mounting them to my Rongfu round column mill.
You should be able to ensure the VFD doesn't restart after a power outage (or any fault). Look at the user manual, and adjust the "ATR" functions value to "no". (pg 62 of the pdf linked below).One detail that I noticed in my testing of the the VFD is that it will return power to the drive upon a power outage/restart.
Good plan. I have done exactly as you are doing with great success. Zero failures with used motors and used Altivars. I'm not sure but I think the 18 supports both a breaking resistor and SVC those are the cherry on the sundae features. FWIW my used non VFD rated motors run as cool as a cucumber even at low RPM.Here are the pieces I bought. The motor is a 2 HP, 240v, 3-phase Baldor motor, replacing my previous 1/5 HP 240v, 1-phase Princess Auto motor. The VFD is a Square-D (Schneider) Altivar 18, rated for 240V and 1.5KW (2 HP) that was surplussed from an industrial installation. Both pieces are well used, but I bench tested them and all seems well. The only hiccup so far is the cooling fan on the VFD which was missing some or the fan blades. It was bit unbalanced and noisy upon startup, and then it self destructed after a short period of time. Got a replacement from Digikey for about $25, so not too upset about that.
I assume you know that they will run cool with no load. It's when they are loaded that it becomes an issue.
