Finding acme 1/2-20 threaded rod is non existent to repair/replace an Atlas 618 lead screw. Would 1/4-20 or 3/8-20 acme have enough strength to pull the table across? Would it also allow me to use the same gear ratios for thread cutting because it’s 20TPI only half the size?
I know I would have to make a new half nut in 1/4 or 3/8. I remember my Sherline Lathe had a small lead screw. I’m just throwing this out there. I must have been absent the day we studied lead screws and gear ratios in machine shop.
Or could it be converted to standard 1/2-20 standard 60 degree threads and still cut decent threads with the gear clusters.
