I found hairline crack on the main pulley driven directly by the motor:
When assessing risk, I like to try to put things in terms I can relate to.
10 inch diameter sheave spinning at 1750 RPM means the outer edge of your sheave is doing about 50 mph. If it's 3600 RPM, it's about 100 mph.
I've been hit in the forehead by a bee while doing 60 mph on a motorbike. Sure glad it wasn't a few ounces of steel.
I'm trying to understand what would have caused those cracks in the first place. My guess is this is not steel, it's cast iron (maybe nodular iron), and I'm guessing it was pressed on. Does it run true, or does it wobble?
Failure would likely mean one of the small chunks flies off from adjacent to the shaft (where the visible cracks are). Their velocity would be much less, so that's good. But, what the rest of the sheave does after the hub comes apart is anybody's guess.
This has a skookum belt guard around it, right?
I found some basic information but nothing too detailed about the tapered pin. Knock it out and put it back in is essentially all of the instruction.My very first question on reading this was: What caused the cracks to happen?
The pulley is cast iron no?
This tapered pin is...... ?
If it is tapered, is the fattest diameter of the pin bigger than the hole? Could it have been tightened enough to initiate cracking?
I don't think all these radial cracks suggest overloading of the pulley shaft or relative movement between the pulley and shaft. However, they could be formed by overtightening the tapered pin.
I think the reason for a tapered pin is to take up all the clearance in the hole so that the pulley cannot move relative to the drive shaft. Likely, the first design was a straight pin. That was changed to a tapered pin when the hole started to wear from relative movement of the pulley and shaft.
But I'd bet there was a tightening spec on that pin. Either for driving or torque.
I think those cracks are from overtightening the pin - either driving it or torquing it.
I'd favour an exact fit shear pin over a tapered pin.
I also like @Darren's collar idea. But when you make the collar keep in mind that these cracks are likely caused by the pin not by the shaft load. So the collar should be installed and tightened before the pin.
I don't think brazing or welding will help. The expansion caused by the pin must be dealt with or it will just crack elsewhere.
Do you have an owners or Service Manual for that machine? If so, look up that pin and the install procedure.
I could also be all wet. But those are my thoughts on it without the benefit of being there.
That would be appreciated. Thank-youI will try and remember to dig around and have a look in the seacan tomorrow..... I might have one of those kicking around....
I have a Dayton brand, 2 piece, shaft collar clamp on order for next week.
It looks like you have a plan in place, but if things go a little bit sideways, I have one left in the tickle trunk......That would be appreciated. Thank-you
And don't drive the tapered pin out from the wrong side and crack it.I wouldn’t worry too much about it, the tapered pin still goes through the shaft and the other side of the collar so it shouldn’t give a problem, if I was worried about it I’d cut a groove down the crack and braze it. Or even easyer drill another hole 90 deg to it and use a taper reamer to size for the pin.
And don't drive the tapered pin out from the wrong side and crack it.![]()
I will keep this offer in mind and once again, thank-you.It looks like you have a plan in place, but if things go a little bit sideways, I have one left in the tickle trunk......
I was thinking about it and the pin came out rather easy. It is definitely tapered and will only go back together one way. Therefore, I don't think I was the culprit. Maybe someone before me made that mistake.^This.
Which might also totally explain what happened in the first place!!!!
It's quite likely that while they were at it they smacked the outer rim of the pulley several times with a mallet to get it off the shaft as well....... That could account for some of the damage I would think.I assumed that! So I got your back on that one!
