Spring 2024 meetup in Calgary - tentative date Saturday, April 20/2024.
Other regions are also discussing meet ups. If you want one in your area get going on organizing it! discussion
We are having email/registration problems again. Diagnosis is underway. New users sorry if you are having trouble getting registered. We are exploring different options to get registered. Contact the forum via another member or on facebook if you're stuck. Update -> we think it is fixed. Let us know if not.
Spring meet up in Ontario, April 6/2024. NEW LOCATION See Post #31 DiscussionNEW LOCATION
Ok I have started this thread to fix some issues that may have been present with my other user name. This thread however just continues from my other thread.
Johnwa I have used jb weld on external engine repairs before but I am somewhat concerned being oil soakred with lots of vibration and heat that a failure may occur. If it gets caught up in the chain and the engine being an interference engine bad things may happen.
Apparently JB weld over time with heat cycling will shrink so its my opinion that this would be a temporary fix..
Now I'm leaning on turning a copper pin and having it tig welded as Tom had suggested. If anyone knows a shop with a resonable rates and a lot of experience that would be great.
Found a replacement chain guide retaining pin one side a bevel which needs to be present once reconstructed the other side threaded for pin removal with a slide hammer.
Interesting I believe those rods are simiar to durafix low temp aluminum brazing rods that require mapp gas. I have another head which is awaiting recycling I could drill a hole and you could see if it would work out. If you are game emai me and we can discuss. We would just need a straight edge to measure the matting surface before and afterward. Oh and have a copper pin made.
